object naming
All  1  2-11
7739.2 In reply to 7739.1
Without Script just make a little file text with your names whished!
So just make a copy past from this list when needing! ;)
Not a big deal! :)
You can make the same with names of Scripts / Commands if you don't want install the CUstom UI who is a little tricky to Install!
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
Open your text list of commands/plugins
Copy the one wished
Press Tab
Past it / Enter
Et voilà! :)
7739.3 In reply to 7739.1
Hi wim, there is a script that can help with that, you can find it here:
AssignName - set the name of an object from a list of existing named objects:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3830.4
AssignPresetName - set the name of an object from a fixed preset list of names in a text file:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3830.8
In the future I want to make that possible from within the scene browser itself, but for now the AssignName plug-in should help.
7739.4
Thanks Michael. the script will do for the moment, looking forward to the (slightly more) ergonomic solution inside the UI!
wim
7739.5
For ver 4
Perhaps a button that comes up next to the names already allocated, like the coloured ones have
then you can select the new items and add with 1 click to any on the list
cheers
shayne
7739.6 In reply to 7739.5
Hi shayne,
> the coloured ones have then you can select the new items and add with
That could be a possibility, but it's a bit awkward to try and make a good visual representation of what that little button would do... One thing I've tried to avoid with the scene browser is having it get cluttered up with too many columns of controls which are not immediately recognizable for what they would do.
So another idea that I've had is to make a button that would open a drop down menu and then on that menu there could be some items, one of which could be "Assign to this name"... That would help for future functions as well since they could easily be added to that menu and stay out of the way most of the time.
But either one of those is possible, I just have not had time yet to prototype them.
7739.7
this is what I had in mind.
wim
7739.8
but I like the AssignName command too! equal ergonomics!!
7739.9
Hi Michael et al,
Is there a way to name an object selection without having to click on "Unnamed" in the upper right UI corner? I'm thinking of a keyboard-assignable command / inline script that pops up the name input field.
Thanks!
Regards,
— Metin
visualization • illustration • animation • 3D design — metinseven.nl
7739.10 In reply to 7739.9
Hi Metin, yes see here for a script you can set up on a shortcut key that will do the same thing as clicking to set the object name:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5738.2
7739.11 In reply to 7739.10
Great, thank you Michael!
Regards,
— Metin
Show messages: All  1  2-11
