option to remove view icons from viewport
All  1-3  4-6
773.4 In reply to 773.3
I use reset a lot as well.
I've run into the same problem where I'm trying to drag or adjust something at the extreme bottom of the viewport and the buttons pop up getting in the way - yes, you do have to stop what you're doing and readjust - I've just learned to accept it.
Granted, perhaps if MOI maintained a flag "Dragging" for example while moving or manipulating an object, then when the cursor gets within the widget area, if that flag is TRUE perhaps the display of the buttons could be temporarily suspended?...
Another option could be to hover your cursor over that area for a specified time but that doesn't guarantee that won't happen while manipulating something at the extreme bottom of the viewport PLUS that slows you down waiting for the widgets to display - definitely not a elegant solution IMO.
-Will
773.5
I found the icons in the view to be getting in the way as well when using the keyboard I think this is something to be considered as an option in user preferences.
773.6
I for one love the way these icons work just as they are.
Sure, it takes a second to re-adjust things sometimes when you happen to drag over the spots occupied by the icons but you get so used to it when you model alot in MOI that it simply becomes something you either accept (as I do) or set up your scene beforehand to avoid. For me it's no big deal at all and I punch out tons of models mothly in MOI, well, at least 40 a month for sure.
I use the "reset" icon constantly in my workflow as either a "frame all" (when nothing is selected beforehand) or as a handy "frame selected" function. These actually feel very intuitive to me in my workflow and I love them as they are.
If this existing method does change much I'm not so sure I'd welcome the change unless it were just a matter of users being able to "switch off" these features which I enjoy and apparently you do not.
- 3dvisuals dude
Show messages: All  1-3  4-6
