Aligning Images
All  1-10  11-16
7725.11 In reply to 7725.10
Dear Pilou,
I have modified the properties of the images as you suggest. I am learning something new. Does this version of the file include the images?
Sincerely,
Bill
7725.12 In reply to 7725.11
<< Does this version of the file include the images?
Of course yes! We are in 2015! ;)
And yes there is a little problem with the side views! In height and weight ...for the reactor (?) and also for the top of the cabin!!!
So you must adapt it! Maybe original image was deformed on the 2D prog ...
EDITED: 18 Nov 2015 by PILOU
7725.13 In reply to 7725.9
Hi Bill,
> The problem that I have is that if you draw a line from the leading edge of the engine inlet in the
> top view, it does not line up with the engine in the side view. This misalignment would be critical.
Probably the images are not accurate - if the images are just kind of quick sketches that have differences between them then there won't be any way to align them 100%.
They need to be accurate views of the same exact object if you want them to align properly.
7725.14 In reply to 7725.12
Thank you very much for helping me understand better the process of aligning images. I agree with you that this particular 3view is nou accurate enough and I will look for a better one
Sincerely
Bill
7725.15 In reply to 7725.14
Hi Bill,
is that a Gulfstream G500/G550? Otherwise I converted( to PDF via Photoline) and imported the SVG-file from this Wikipedia article https://en.wikipedia.org/wiki/Gulfstream_G550#Specifications. These are actually all unconnected curves, no tracing necessary. I grouped the curves and named them after their initial view, so front, side and top. Might be of some help, i dunno.
Best,
Marco
7725.16 In reply to 7725.15
Marco,
Thank you very much for your input. I found it very interesting. I am not sure that I no what an SVG file, or how you obtained it, but your geometry matches much better than the 3 view that I had.
Thank you again for you help and guidance.
Show messages: All  1-10  11-16
