Parametric design in MoI?
 1-20  …  721-740  741-760  761-780  781-800  801-820  …  901-912
7713.761 In reply to 7713.760
Forgotten this tricky trick! ;)
EDITED: 4 Jan 2018 by PILOU
7713.762 In reply to 7713.761
With this extended Tool you get also the Polylines to make it easier for FLOW operations...
The cyan line is for the dove cutting the blue for the tinnes and the magenta (selected on pict) is the baseline.
Ralf:)
looking for moments of inspiration...
7713.764 In reply to 7713.763
Wow ! Merci Pilou !
Ralf:)
7713.765 In reply to 7713.762
Sinusoïdal!! :)
PS A little video will be fine for all the process!
Say for an Ellipse...rectangular :)
7713.766
Happy New Year to all .
I have a problem that I think is easily solved on your part,
I wanted to install the latest version of December 2017 ,
the one that has a new code to create a shortcut...
What I have to insert in the UI folder inside Moi, you just need to unzip the file
or do I have to create new folders ....?
Someone can give me some info maybe with some screenshots
that shows how to place the folders inside the folder ui ..
Thank you and sorry for my ignorance
alberto
7713.767 In reply to 7713.766
Hi Alberto
Windows: extract archive to C:\Users\<username>\AppData\Roaming\Moi\nodeeditor
Mac: extract archive to /Users/<username>/Library/Application Support/Moi/nodeeditor
Run this command to open Nodeeditor window:
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
7713.768
Few weeks ago I bought a 4k monitor, and as a result, Nodeeditor is fully compatible with HiDPI displays. :)
Mac version looks great (check the attached file), but i still have a problems with Windows version. (I will ask Michael about it)
EDITED: 7 Mar 2022 by SMIRNOV
7713.769
Thanks Max for the detailed information
Happy New Year and Good Job
Thanks again
best
alberto
7713.770
Nodeeditor 1.0 release candidate 1
added: HiDPI/Retina screen support. Now NE interface depends on system dpi settings and system UI scale. Should work good with all MoI versions: v3/v4 Win/Mac. Please test it.
removed: css files. I removed all waste from css files, and moved css data to index.html.
changed: context menu and info panel design
added: alt+double click - reset viewport
changed: alignToGrid function (now you can't create two nodes with same coordinates)
http://moi.maxsm.net/nodeeditor/
7713.771 In reply to 7713.770
Seems new translations (if new nodes or other goodies)
and
Updates French site in perspective! :) Site Fr - Done : http://moiscript.weebly.com/elephant-systegraveme-nodal.html
EDITED: 20 Jan 2018 by PILOU
7713.772 In reply to 7713.770
Great work Max, almost at 1.0 !
7713.773 In reply to 7713.770
Wanderful!!!! Thanks Max!!
@Max
file lang.js with French translations of official and "deviant" nodes! ;) (1.0 Canddidate)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_21_01_18_vf.zip
7713.775 In reply to 7713.767
Hi Max,
I've just returned from 6 weeks away, and are attempting to update nodeeditor.
I've attached the code: "moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );" to NE icon in custom UI
and extracted archive into folder directory as per your instructions (?)
But alas, it opens a blank window.
Please let me know if I done something wrong (I'm still a bit jet-lagged)
Thanks James
EDITED: 30 Jan 2018 by JFH
7713.776 In reply to 7713.775
<< Blank window
Sure not : take a look at the right column of the Core Folder! ;)
There is a vertical list!
All is present! :)
7713.777 In reply to 7713.775
Hi James, which version of MoI are you running it on?
7713.778 In reply to 7713.777
>> which version of MoI are you running it on? <<
MoI v4 beta Dec-11-2017
UPDATED: I've updated to MoI v4 beta Dec-12-2017
but again blank window
7713.779 In reply to 7713.775
Hi James, taking a closer look at your directories there, it looks like the problem is you've got it in the root /Library instead of your user one.
Put it just as you have done except under /Users/[your user name]/Library/Application Support/Moi - you should find a Moi directory there already which has your moi.ini file in it.
Hopefully that should get you going!
7713.780 In reply to 7713.779
Thank you Michael,
I had forgotten that Apple hides the User Library files by default
(tip for Mac users: Cmd Shift . [period] will unhide hidden system files)
So all good now.
While I've got you: there is a bug with interacting with NE interface via MacBook trackpad,
which Max is unable to reproduce because he doesn't have access to these devices (macbook or mac trackpad).
I've not experience any similar issue with Moi v4 interfacing, so it is likely to be specific to Max's
code, but is there something within the rewriting of v4 that has altered the handling of trackpad events
that may have follow on effects? I understand that NE operation is outside your principle concern, but if
there is something obvious to you that may cause this issue, perhaps you could steer Max right.
Either way, thanks again for your help
Show messages:  1-20  …  701-720  721-740  741-760  761-780  781-800  801-820  821-840  …  901-912
