Parametric design in MoI?
 1-13  …  714-733  734-753  754-773  774-793  794-813  …  894-912
7713.754
Hi Ralf,
thankĀ“s for the extensions. Integrated it in the extension folder. Now I must find out, what to do with them.
7713.755
Because i think that this is the first of my Node creations which i think is USEFULL i post it in this thread...
THE DOVETAIL TRAY MAKER
HOW TO USE IT
Open the attached dovetailcase5.nod in MoI > hit run... and you see this:
Change the dovetails to your needs. And hit APPLY
NOW SWITCH BOTH SWITCHES ("Left/Right" and "Boards") and you can design a different Dovetail for the opposite side...
HIT APPLY AND CLOSE THE NODEEDITOR...
You will see the tray with the dove maker tools
Now select the upper and lower board and DO A BOOLEAN DIFFERENCE with the correspondending (the outer ones) tools to cut the dovetails:
Do the same with the other two boards:
You have the dovetail tray!
Do some small chamfer...
You can also make a small gab between the two parts - VERY USEFULL IF YOU 3D PRINT IT - and it brings a snuggly fit...
As a joiner i would be proud of it!
And there are NO SPECIAL EXTENSIONS used..
HAVE FUN !
EDITED: 3 Jan 2018 by R2D3
7713.756 In reply to 7713.755
@r2d3
Will be fine if any 2 intersected volumes can be used! ;)
French version is in Progress!
EDITED: 3 Jan 2018 by PILOU
7713.757 In reply to 7713.756
"Open the attached dovetailcase5.nod in MoI > hit run... and you see this:"
Hi
When i load dovetailcase5.nod i can't hit run (show screenshot)
and a part of nodes are red..
EDITED: 9 May 2020 by FINEMA
7713.758 In reply to 7713.757
Your node extensions are not up to date...
Look here for a actual one...
http://moi3d.com/forum/index.php?webtag=MOI&msg=7713.753
Have fun
Ralf:)
looking for moments of inspiration...
7713.759 In reply to 7713.758
Thanks Ralf ! it's great !
7713.760 In reply to 7713.756
Let the Dove-tools jump over a FLOW-command and you can do also round edges...
Ralf:)
7713.761 In reply to 7713.760
Forgotten this tricky trick! ;)
EDITED: 4 Jan 2018 by PILOU
7713.762 In reply to 7713.761
With this extended Tool you get also the Polylines to make it easier for FLOW operations...
The cyan line is for the dove cutting the blue for the tinnes and the magenta (selected on pict) is the baseline.
Ralf:)
7713.764 In reply to 7713.763
Wow ! Merci Pilou !
Ralf:)
7713.765 In reply to 7713.762
SinusoĆÆdal!! :)
PS A little video will be fine for all the process!
Say for an Ellipse...rectangular :)
7713.766
Happy New Year to all .
I have a problem that I think is easily solved on your part,
I wanted to install the latest version of December 2017 ,
the one that has a new code to create a shortcut...
What I have to insert in the UI folder inside Moi, you just need to unzip the file
or do I have to create new folders ....?
Someone can give me some info maybe with some screenshots
that shows how to place the folders inside the folder ui ..
Thank you and sorry for my ignorance
alberto
7713.767 In reply to 7713.766
Hi Alberto
Windows: extract archive to C:\Users\<username>\AppData\Roaming\Moi\nodeeditor
Mac: extract archive to /Users/<username>/Library/Application Support/Moi/nodeeditor
Run this command to open Nodeeditor window:
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
7713.768
Few weeks ago I bought a 4k monitor, and as a result, Nodeeditor is fully compatible with HiDPI displays. :)
Mac version looks great (check the attached file), but i still have a problems with Windows version. (I will ask Michael about it)
EDITED: 7 Mar 2022 by SMIRNOV
7713.769
Thanks Max for the detailed information
Happy New Year and Good Job
Thanks again
best
alberto
7713.770
Nodeeditor 1.0 release candidate 1
added: HiDPI/Retina screen support. Now NE interface depends on system dpi settings and system UI scale. Should work good with all MoI versions: v3/v4 Win/Mac. Please test it.
removed: css files. I removed all waste from css files, and moved css data to index.html.
changed: context menu and info panel design
added: alt+double click - reset viewport
changed: alignToGrid function (now you can't create two nodes with same coordinates)
http://moi.maxsm.net/nodeeditor/
7713.771 In reply to 7713.770
Seems new translations (if new nodes or other goodies)
and
Updates French site in perspective! :) Site Fr - Done : http://moiscript.weebly.com/elephant-systegraveme-nodal.html
EDITED: 20 Jan 2018 by PILOU
7713.772 In reply to 7713.770
Great work Max, almost at 1.0 !
7713.773 In reply to 7713.770
Wanderful!!!! Thanks Max!!
Show messages:  1-13  …  694-713  714-733  734-753  754-773  774-793  794-813  814-833  …  894-912
