Parametric design in MoI?
 1-11  …  692-711  712-731  732-751  752-771  772-791  …  912
7713.732
Frenchy Pilou
>>Seems node Octane is not include in this last Opus !
As I wrote earlier the Octane node is extension. I have no plans to include it in the main nodeeditor pack.
>>OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
At the moment it works with MoIv4 only.
Marco
>>But...how can I display the icon ? Where the icon files must be placed ? is there a naming convention for the icon files ?
The icon should be specified inside a node file as a base64 encoded string parameter.
Check this file: http://moi.maxsm.net/nodeeditor/extensions/octane.js
>>I got so excited reading this, because I assumed that you must have tested interfacing with a trackpad.
Unfortunately I still have no idea how to emulate a trackpad. I tried programs like mobilemouse, but those programs can't emulate a touchpad events.
>>But the same interfacing issues persist: Zooming & panning in NE interface work only intermittently. And other odd behaviours where panning is misinterpreted as attempt to move a node's location.
I remember about it.
Could you add a line to main.js?
Find this code (line 4525):
LGraphCanvas.prototype.touchHandler = function(event)
    var touches = event.changedTouches, first = touches[0], type = "";
	switch(event.type)
change it to:
    if ( touches.length > 1 ) return;
	switch(event.type)
7713.733 In reply to 7713.732
<<OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
<< At the moment it works with MoIv4 only.
"not the logo" on title's node : so it's a personnal variation not include on your extension published?
7713.734 In reply to 7713.732
Hi Max!
@You : "...The icon should be specified inside a node file as a base64 encoded string parameter.
Check this file: http://moi.maxsm.net/nodeeditor/extensions/octane.js"
Thanks a lot for the info.
Last question...
Which size and format the icon should be ? Png 24 bit (8red,8gree,8blue with transparent background) as we talked about months ago ?
Ciao.
7713.735 In reply to 7713.734
Hi Marco,
> Which size and format the icon should be ? Png 24 bit (8red,8gree,8blue with transparent background) as we talked about months > ago ?
If you decode the string it will give you (for his Octane Logo) a 24bit .png with a transparent background, 32x32 pixels in size.
7713.736 In reply to 7713.734
Hi Marco
If I remember clearly, we decided to use 64x64x24 bit icons :)
This octane 32x32 icon is just a test.
7713.737 In reply to 7713.734
Thanks Stefan for the tip.
Have a nice day.
7713.738 In reply to 7713.736
Hi Max.
Perfect! I think 64x64 is perfect for any kind of display monitor (both SD/HD/Retina)
One question...
Is there a way to attach and display the icons also for the "categories" end the "nodes"displayed into the scrollable toolbar on the left and int the RMB pupoup menu ?
This would be a great and nice UI improvements.
For example i never use the RMB manu but only the left toolbar that is much more user freindly for me, and having the chance to display icons and/or colored icons into that toolbar would be very useful.
I stay tuned. Thanks.
7713.739 In reply to 7713.738
So how do you put this little title logo ? :)
You must enter in the code?
7713.740 In reply to 7713.739
if you mean the little Octane logo you have to use a base64 encoder/decoder in cmd.exe and run on a little png image
"base64 -e image.png > output.txt" and then copy the text from the output file in a string, like shown in Max's code example.
7713.741 In reply to 7713.732
Hi Max
>> Could you add a line to main.js? <<
Yes. Although the line of code change did not fix the problem outright,
it has, at least, made NE on v4 useable, so thank you.
7713.742 In reply to 7713.740
This is super handy : https://www.base64-image.de/
Marco (mkdm)
7713.743 In reply to 7713.740
<< if you mean the little Octane logo
Yes :)
So I must read the code and make some headache tricky manipulations for the Nodes Menu!
Wish only one must be made for have the same on the screen of the node Logo Octane Tittle ? :)
i don't use Node Editor but as understood you must create an icon for every node you like to have an icon in.
So if you look at Max's code example you see how it should be done, in case you like to put an icon in your
own node file.
7713.745 In reply to 7713.743
Hi Pilou!
No tricky or headache at all if you are a little bit familiar with this kind of things :)
Just use the online tool I've reported (https://www.base64-image.de/) and follow this little example (pseudo code) :
// This is a js node definition file placed inside the "extensions" folder
function NameOfTheNode() {
	... js code of the constructor function of the node
// here is the section that is important for you
NameOfTheNode.title = "NodeTitle";
NameOfTheNode.desc = "Node description";
NameOfTheNode.icon = "data:image/png;base64,xxxxxxxxxxxxxxxx";
Where "xxxxxxxxxxx........" is the base 64 code generated by the online tool (https://www.base64-image.de/)
Nothing more than that :)
7713.746 In reply to 7713.745
Ok I have made my own for be sure to understand what i made! :)
With SumpoPaint of course! :)
https://www.sumopaint.com/home/#app
Just curious logo is not centered on the Menu's Lines?...
Maybe the original is not exactly at the center...
Edit : even the original is centered result is bottom offseted! ?
EDITED: 18 Dec 2017 by PILOU
7713.747 In reply to 7713.728
Hello Max,
I made a first experiment with an icon. Is it true that we will lost the node state (green, orange,red).?
Have a nice evening
Karsten
7713.748
I have been playing with adding Icons in the node editor to see if they can be recognised at the 64 x 64 size.
On my surface Pro even when zoomed in I don't think over detailed icons will be recognised.
Any idea's on best colour's ?
Barry
For Max and all nodes lovers! :D
Official nodes + Extensions!
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang_21_12_17_vf.zip
7713.750
Hallo together,
where can I find the current instructions how to install the nodeeditor on V4.
7713.751 In reply to 7713.750
Ralf:)
looking for moments of inspiration...
Show messages:  1-11  …  672-691  692-711  712-731  732-751  752-771  772-791  792-811  …  912
