Parametric design in MoI?
 1-19  …  680-699  700-719  720-739  740-759  760-779  …  900-912
7713.720
Marco
>>After a simple loading of the new NE for V4 and a couple of simple tests, all worked fine with this updated NE.
Thank you for testing. I didn't change the internal structure, so anything should work good.
>>I want to apologize to you because some times ago I told you that was my intention to build a new UI for P. Elephant, but, as you can see, I didn't make anything so far.
It's not a problem :)
Frenchy Pilou
Thank you for the translation file. I added it to the pack.
7713.721 In reply to 7713.720
It's my pleasure! :)
Message 7713.722 deleted 26 Nov 2017 by JFH
7713.723
v.0.99
Added Transform/Twist node
Added Transform/Flow node
Added Basic/Concat
Removed Objects/Concat
Removed Points/ConcatPts
Fixed JitterPts bug
Added JitterPts Update function
http://moi.maxsm.net/nodeeditor
New node Basic/Concat supports all data types.
Objects/Concat and Points/ConcatPts are obsolete. I removed them from nodeeditor.
Don't worry if you use this nodes in your nod-projects. I added compatibility records to core/compatibility.js.
Old nodes will be replaced with the new one automatically.
7713.724 In reply to 7713.723
Hello Max!
@You : "...Don't worry if you use this nodes in your nod-projects. I added compatibility records to core/compatibility.js.
Old nodes will be replaced with the new one automatically..."
That's great!!
Thanks a lot.
Ciao!
For Max : the French lang.js update for the 0.99 nodeeditor
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
7713.726
v0.99
Changed link disconnection method (please test it)
Fixed Quartz output bug (v0.96-v0.99)
Updated french localization
http://moi.maxsm.net/nodeeditor/
Near the 1.0 ! :)
7713.728
nodeeditor.v.0.99.2017.12.18
added: nodeeditor can be started from appdata directory
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
fixed: knob/slider trackpad scroll error
fixed: small visual glitch
added: switch/button node
fixed: pointArray.concat function
fixed: JitterPts node (dS bug)
added: initial node icons support
EDITED: 7 Mar 2022 by SMIRNOV
7713.729 In reply to 7713.728
Seems node Octane is not include in this last Opus !
Must we add something from a previous post from the "deviant thread"?
Else new lang.js for French Update ;)
OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
EDITED: 17 Dec 2017 by PILOU
7713.730 In reply to 7713.728
Hello Max!
Thanks a lot for this new update!
I moved NE to my "appdata\Roaming\Moi" and all works fine (on Windows 10 Pro)
@You : "...added: initial node icons support..."
Wow! Much appreciated :)
But...how can I display the icon ? Where the icon files must be placed ? is there a naming convention for the icon files ?
Thanks.
7713.731 In reply to 7713.728
Hi Max,
>> fixed: knob/slider trackpad scroll error <<
I got so excited reading this, because I assumed that you must have tested interfacing with a trackpad.
But the same interfacing issues persist: Zooming & panning in NE interface work only intermittently.
And other odd behaviours where panning is misinterpreted as attempt to move a node's location.
NE on V3.1 all works perfectly.
7713.732
Frenchy Pilou
As I wrote earlier the Octane node is extension. I have no plans to include it in the main nodeeditor pack.
At the moment it works with MoIv4 only.
Marco
The icon should be specified inside a node file as a base64 encoded string parameter.
Check this file: http://moi.maxsm.net/nodeeditor/extensions/octane.js
Unfortunately I still have no idea how to emulate a trackpad. I tried programs like mobilemouse, but those programs can't emulate a touchpad events.
>>But the same interfacing issues persist: Zooming & panning in NE interface work only intermittently. And other odd behaviours where panning is misinterpreted as attempt to move a node's location.
I remember about it.
Could you add a line to main.js?
Find this code (line 4525):
LGraphCanvas.prototype.touchHandler = function(event)
    var touches = event.changedTouches, first = touches[0], type = "";
	switch(event.type)
change it to:
    if ( touches.length > 1 ) return;
	switch(event.type)
7713.733 In reply to 7713.732
<<OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
<< At the moment it works with MoIv4 only.
"not the logo" on title's node : so it's a personnal variation not include on your extension published?
7713.734 In reply to 7713.732
Hi Max!
@You : "...The icon should be specified inside a node file as a base64 encoded string parameter.
Check this file: http://moi.maxsm.net/nodeeditor/extensions/octane.js"
Thanks a lot for the info.
Last question...
Which size and format the icon should be ? Png 24 bit (8red,8gree,8blue with transparent background) as we talked about months ago ?
Thanks.
Ciao.
7713.735 In reply to 7713.734
Hi Marco,
> Which size and format the icon should be ? Png 24 bit (8red,8gree,8blue with transparent background) as we talked about months > ago ?
If you decode the string it will give you (for his Octane Logo) a 24bit .png with a transparent background, 32x32 pixels in size.
7713.736 In reply to 7713.734
Hi Marco
If I remember clearly, we decided to use 64x64x24 bit icons :)
This octane 32x32 icon is just a test.
7713.737 In reply to 7713.734
Thanks Stefan for the tip.
Have a nice day.
7713.738 In reply to 7713.736
Hi Max.
Perfect! I think 64x64 is perfect for any kind of display monitor (both SD/HD/Retina)
One question...
Is there a way to attach and display the icons also for the "categories" end the "nodes"displayed into the scrollable toolbar on the left and int the RMB pupoup menu ?
This would be a great and nice UI improvements.
For example i never use the RMB manu but only the left toolbar that is much more user freindly for me, and having the chance to display icons and/or colored icons into that toolbar would be very useful.
I stay tuned. Thanks.
7713.739 In reply to 7713.738
So how do you put this little title logo ? :)
You must enter in the code?
Show messages:  1-19  …  660-679  680-699  700-719  720-739  740-759  760-779  780-799  …  900-912
