Parametric design in MoI?
 1-11  …  32-51  52-71  72-91  92-111  112-131  …  912
7713.72 In reply to 7713.70
I guess Max could, say for nodeeditor.v.0.22.alpha, include subdirectory nodeeditor below the alpha directory.
Of course nodeeditor would contain the core, css, nodes, etc subsubdirectories and file contents.
Then to update, the subdirectory nodeeditor (with its contents) could be copied to /ui, rather than unzipping and copying core, css, nodes, etc, to ui/nodeeditor.
I had to think which updated directories to copy :-)
7713.73 In reply to 7713.71
Hi speedy
Absence of rotate happened to me, the very first time only. May be a file buffer issue?
Maybe close and re-open Moi. (pressing F5 once, helps with the file buffer?)
7713.74
many tnx bemfarmer.. for the info...
but ,I have resolved the problem....
I extract the content of folder ( node 2015.12.01)
and then copy and paste into the initial folder (nodes)
in Mou-ui , replacing the old file.js so-
Now it's work very well...
tnx
al
Size: 240 KB, Downloaded: 56 times, Dimensions: 2192x1648px
7713.75
Oh, my fault %)
I noticed that mess with the folders yesterday. I repacked an archive, but then I reuploaded the first one. :) Sorry guys.
EDITED: 7 Mar 2022 by SMIRNOV
7713.76
>>Lancer --> Stop --> Run !!!
Pilou, thank you for report. Fixed.
Also I fixed a critical bug, which cause errors on wire disconnection.
7713.77 In reply to 7713.76
Hi Max,
I have made some experiments with your code and have some problems with the frames. The following code fragment works, but with frames not. Have you any idea what I'm doing wrong?
// Line
function Line()
// this.size = [60,20];
// this.addInput("Start","frame"); //<------
// this.addInput("End","frame"); //<------
this.addInput("x1","number");
this.addInput("y1","number");
this.addInput("z1","number");
this.addInput("x2","number");
this.addInput("y2","number");
this.addInput("z2","number");
this.addOutput("Out","objectlist");
// this.properties = { radius:0 };
Line.title = "Line";
Line.desc = "Line";
Line.prototype.onExecute = function()
// var start = this.getInputData(0, moi.VectorMath.createFrame()); //<--------
// var end = this.getInputData(1, moi.VectorMath.createFrame()); //<-------
this.properties.x1 = this.getInputData(0, this.properties.x1);
this.properties.y1 = this.getInputData(1, this.properties.y1);
this.properties.z1 = this.getInputData(2, this.properties.z1);
this.properties.x2 = this.getInputData(3, this.properties.x1);
this.properties.y2 = this.getInputData(4, this.properties.y2);
this.properties.z2 = this.getInputData(5, this.properties.z2);
var start = moi.vectorMath.createPoint();
var end = moi.vectorMath.createPoint();
start.x = this.properties.x1;
start.y = this.properties.y1;
start.z = this.properties.z1;
end.x = this.properties.x2;
end.y = this.properties.y2;
end.z = this.properties.z2;
var factory = moi.command.createFactory( 'line' );
factory.setInput(0, start);
factory.setInput(1, end);
var output = factory.calculate();
// factory.update();
// LineFactory.commit();
this.setOutputData(0, output);
factory.cancel();
LiteGraph.registerNodeType("Factories/Line", Line);
Please, keep on coding:-)
Thanks a lot!
Karsten
7713.78 In reply to 7713.77
EDITED: 5 Dec 2015 by BEMFARMER
7713.79 In reply to 7713.78
Have you an idea of the use of Node "Loft" ?
7713.80
Hi Karsten,
check this manual
http://moi.maxsm.net/api/#_CoordinateFrame
If you want to use frames as input data you can use this code:
function Line()
Line.desc = "Line";
	factory.setInput(0, start.origin);
	factory.setInput(1, end.origin);
	factory.cancel();
but it will be better if you use points instead of frames
function Line()
	this.addInput("Start","point");
	this.addInput("End","point");
Line.desc = "Line";
	var start = this.getInputData(0, moi.VectorMath.createPoint());
	var end = this.getInputData(1, moi.VectorMath.createPoint());
	factory.cancel();
7713.81
Frenchy Pilou
7713.82 In reply to 7713.80
Hello Max,
thank You very much - I didn't know about ".origin" in the construct. But now everything makes sense.
Have a nice day
Karsten
7713.83 In reply to 7713.81
@ Max
Aaaaaaaaaaaaaaah! In all my trys I put "Loft" on start and not at the end! That was the trick! :)
Very cool that we can reload the entiere set of nodes!
That is parametric indeed! Bravo!
Just something curious all nodes titles are not translated !
I will investigate (i have not yet dowloaded your last version !)
EDITED: 4 Dec 2015 by PILOU
@Max
Even with your last version v 0.23Alpha
Reloading the "loft.nod" file don't make appear translated French Tittles of the Nodes!
Internal lines are translated!
So Little Glitch;
French version is present as you can see!
7713.85 In reply to 7713.84
It's not a glitch. When you create a node with English/French/Russian name it will be saved in a nod-file. When you load this file all names will be loaded as they stored.
7713.86 In reply to 7713.85
@Max
But this persists when I resave it from my "French" version! ;)
So I must rename first all titles that is some painfull! :)
Or there is a little trick ?
NOT A PRIORITY PROBLEM !!! :)
EDITED: 5 Dec 2015 by PILOU
7713.87
But why translate it
7713.88 In reply to 7713.87
< Why ...
For the beauty of the perfection! ;)
I am agree that is nothing but when it's "default" buttons that is better to see them in their local language! :)
Sure that is more coding at the start but ...that is not priority one! :)
I prefere have more functions than this very very little annoyous trouble! :)
7713.89
Hello,
here is another try to implement a new node - unfortunately with a bug in the menudisplay - I hope Max can help again:-)
Here is the code:
//Curve
function Curve()
this.addInput("In","objectlist");
Line.title = "Curve";
Line.desc = "Curve";
Curve.prototype.onExecute = function()
var inObj = this.getInputData(0, moi.geometryDatabase.createObjectList());
var factory = moi.command.createFactory( 'interpcurve' );
// factory.createInput('point');
for ( var n = 0; n < inObj.length; ++n )
{ factory.createInput('point');
factory.setInput(n,inObj.item(n).pt);
factory.cancel();
LiteGraph.registerNodeType("Factories/Curve", Curve);
I hope it's useful and Max or someone else see my bug:-)
Kind regards
and a nice weekend to all!
Karsten
EDITED: 18 Dec 2017 by KMRQUS
7713.90 In reply to 7713.89
Hi Karsten
Finally found the simple error.
Line needs to be replaced with Curve, twice
ICurve.title = "ICurve";
ICurve.desc = "ICurve";
I renamed it ICurve, because ControlPoint curves are also possible.
Now I will try the simple Catenary to feed into ICurve.
7713.91 In reply to 7713.90
Here is a version of factories.js with Line and InterpCurve nodes.
(This is NOT approved by Max)
Show messages:  1-11  12-31  32-51  52-71  72-91  92-111  112-131  132-151  …  912
