Parametric design in MoI?
 1-13  …  674-693  694-713  714-733  734-753  754-773  …  894-912
<< After a simple loading of the new NE for V4 and a couple of simple tests, all worked fine with this updated NE.,
But not directly the Truchet, etc who are on the // NodEditor ! :)
7713.715 In reply to 7713.714
Hi Pilou!
I'm sorry but I didn't understand what you wanted to say with this sentence : "But not directly the Truchet, etc who are on the // NodEditor ! :)"
Please, could you explain well ?
7713.716 In reply to 7713.715
When I load the Truchet node inside the last "classic" NodeEditor for V4 some nodes are missing! :)
7713.717 In reply to 7713.716
Ah...ok.
I didn't try the "Truchet" nod file, nor any other nod files, I've tested only some "hand-made" nods on the fly.
Ciao!
Some French add functions, links, item...
Lexic list is some cornucopia horn :)
A list of them will be useful because i build it on the fly!
And "Range" is not like "range"! You must have both on the lexic list! :)
First one! :)
and the last for the moment! The Macro :)
Of course you will find these fabulous file on the French Site! :)
and here for Max! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
EDITED: 26 Nov 2017 by PILOU
7713.719
Nodeeditor v0.98 update (No new functions added, so I decided to keep the old version number)
Fixed background flicker on window resize
Fixed touchpad zoom error
Added smooth shadows (v4 only)
Updated french translation (by Frenchy Pilou) Thank you!
Disabled Nodelib Demo UI extension (to enable it rename -ext.mylib.js to ext.mylib.js)
http://moi.maxsm.net/nodeeditor/
EDITED: 26 Nov 2017 by SMIRNOV
7713.720
Marco
Thank you for testing. I didn't change the internal structure, so anything should work good.
>>I want to apologize to you because some times ago I told you that was my intention to build a new UI for P. Elephant, but, as you can see, I didn't make anything so far.
It's not a problem :)
Frenchy Pilou
Thank you for the translation file. I added it to the pack.
7713.721 In reply to 7713.720
It's my pleasure! :)
Message 7713.722 deleted 26 Nov 2017 by JFH
7713.723
v.0.99
Added Transform/Twist node
Added Transform/Flow node
Added Basic/Concat
Removed Objects/Concat
Removed Points/ConcatPts
Fixed JitterPts bug
Added JitterPts Update function
New node Basic/Concat supports all data types.
Objects/Concat and Points/ConcatPts are obsolete. I removed them from nodeeditor.
Don't worry if you use this nodes in your nod-projects. I added compatibility records to core/compatibility.js.
Old nodes will be replaced with the new one automatically.
7713.724 In reply to 7713.723
Hello Max!
@You : "...Don't worry if you use this nodes in your nod-projects. I added compatibility records to core/compatibility.js.
Old nodes will be replaced with the new one automatically..."
That's great!!
Thanks a lot.
Ciao!
For Max : the French lang.js update for the 0.99 nodeeditor
7713.726
v0.99
Changed link disconnection method (please test it)
Fixed Quartz output bug (v0.96-v0.99)
Updated french localization
Near the 1.0 ! :)
7713.728
nodeeditor.v.0.99.2017.12.18
added: nodeeditor can be started from appdata directory
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
fixed: knob/slider trackpad scroll error
fixed: small visual glitch
added: switch/button node
fixed: pointArray.concat function
fixed: JitterPts node (dS bug)
added: initial node icons support
EDITED: 7 Mar 2022 by SMIRNOV
7713.729 In reply to 7713.728
Seems node Octane is not include in this last Opus !
Must we add something from a previous post from the "deviant thread"?
Else new lang.js for French Update ;)
OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
EDITED: 17 Dec 2017 by PILOU
7713.730 In reply to 7713.728
Hello Max!
Thanks a lot for this new update!
I moved NE to my "appdata\Roaming\Moi" and all works fine (on Windows 10 Pro)
@You : "...added: initial node icons support..."
Wow! Much appreciated :)
But...how can I display the icon ? Where the icon files must be placed ? is there a naming convention for the icon files ?
7713.731 In reply to 7713.728
Hi Max,
>> fixed: knob/slider trackpad scroll error <<
I got so excited reading this, because I assumed that you must have tested interfacing with a trackpad.
But the same interfacing issues persist: Zooming & panning in NE interface work only intermittently.
And other odd behaviours where panning is misinterpreted as attempt to move a node's location.
NE on V3.1 all works perfectly.
7713.732
Frenchy Pilou
As I wrote earlier the Octane node is extension. I have no plans to include it in the main nodeeditor pack.
At the moment it works with MoIv4 only.
Marco
The icon should be specified inside a node file as a base64 encoded string parameter.
Check this file: http://moi.maxsm.net/nodeeditor/extensions/octane.js
Unfortunately I still have no idea how to emulate a trackpad. I tried programs like mobilemouse, but those programs can't emulate a touchpad events.
>>But the same interfacing issues persist: Zooming & panning in NE interface work only intermittently. And other odd behaviours where panning is misinterpreted as attempt to move a node's location.
I remember about it.
Could you add a line to main.js?
Find this code (line 4525):
LGraphCanvas.prototype.touchHandler = function(event)
    var touches = event.changedTouches, first = touches[0], type = "";
	switch(event.type)
change it to:
    if ( touches.length > 1 ) return;
	switch(event.type)
7713.733 In reply to 7713.732
<<OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
<< At the moment it works with MoIv4 only.
"not the logo" on title's node : so it's a personnal variation not include on your extension published?
Show messages:  1-13  …  654-673  674-693  694-713  714-733  734-753  754-773  774-793  …  894-912
