Parametric design in MoI?
 1-11  …  672-691  692-711  712-731  732-751  752-771  …  912
7713.712 In reply to 7713.709
Hi Max.
After a simple loading of the new NE for V4 and a couple of simple tests, all worked fine with this updated NE.
But so far I've made only a very basic test.
Anyway...thanks a lot.
Just a side note...
I want to apologize to you because some times ago I told you that was my intention to build a new UI for P. Elephant,
but, as you can see, I didn't make anything so far.
I apologize, but I really never didn't find some decent amount of spare time to put my hands on that task,
and actually my situation isn't changed a lot, so at least for the near future I don't think I will be able to do anything about NE's new UI.
I'm sorry.
Have a nice day.
We'll catch up!
French Nodes of the V4! ;) (Other menus arrive as soon as possible! :)
<< After a simple loading of the new NE for V4 and a couple of simple tests, all worked fine with this updated NE.,
But not directly the Truchet, etc who are on the // NodEditor ! :)
7713.715 In reply to 7713.714
Hi Pilou!
I'm sorry but I didn't understand what you wanted to say with this sentence : "But not directly the Truchet, etc who are on the // NodEditor ! :)"
Please, could you explain well ?
7713.716 In reply to 7713.715
When I load the Truchet node inside the last "classic" NodeEditor for V4 some nodes are missing! :)
7713.717 In reply to 7713.716
Ah...ok.
I didn't try the "Truchet" nod file, nor any other nod files, I've tested only some "hand-made" nods on the fly.
Ciao!
Some French add functions, links, item...
Lexic list is some cornucopia horn :)
A list of them will be useful because i build it on the fly!
And "Range" is not like "range"! You must have both on the lexic list! :)
First one! :)
and the last for the moment! The Macro :)
Of course you will find these fabulous file on the French Site! :)
and here for Max! ;)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
EDITED: 26 Nov 2017 by PILOU
7713.719
Nodeeditor v0.98 update (No new functions added, so I decided to keep the old version number)
Fixed background flicker on window resize
Fixed touchpad zoom error
Added smooth shadows (v4 only)
Updated french translation (by Frenchy Pilou) Thank you!
Disabled Nodelib Demo UI extension (to enable it rename -ext.mylib.js to ext.mylib.js)
http://moi.maxsm.net/nodeeditor/
EDITED: 26 Nov 2017 by SMIRNOV
7713.720
Marco
Thank you for testing. I didn't change the internal structure, so anything should work good.
>>I want to apologize to you because some times ago I told you that was my intention to build a new UI for P. Elephant, but, as you can see, I didn't make anything so far.
It's not a problem :)
Frenchy Pilou
Thank you for the translation file. I added it to the pack.
7713.721 In reply to 7713.720
It's my pleasure! :)
Message 7713.722 deleted 26 Nov 2017 by JFH
7713.723
v.0.99
Added Transform/Twist node
Added Transform/Flow node
Added Basic/Concat
Removed Objects/Concat
Removed Points/ConcatPts
Fixed JitterPts bug
Added JitterPts Update function
New node Basic/Concat supports all data types.
Objects/Concat and Points/ConcatPts are obsolete. I removed them from nodeeditor.
Don't worry if you use this nodes in your nod-projects. I added compatibility records to core/compatibility.js.
Old nodes will be replaced with the new one automatically.
7713.724 In reply to 7713.723
Hello Max!
@You : "...Don't worry if you use this nodes in your nod-projects. I added compatibility records to core/compatibility.js.
Old nodes will be replaced with the new one automatically..."
That's great!!
Thanks a lot.
Ciao!
For Max : the French lang.js update for the 0.99 nodeeditor
7713.726
v0.99
Changed link disconnection method (please test it)
Fixed Quartz output bug (v0.96-v0.99)
Updated french localization
Near the 1.0 ! :)
7713.728
nodeeditor.v.0.99.2017.12.18
added: nodeeditor can be started from appdata directory
moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
fixed: knob/slider trackpad scroll error
fixed: small visual glitch
added: switch/button node
fixed: pointArray.concat function
fixed: JitterPts node (dS bug)
added: initial node icons support
EDITED: 7 Mar 2022 by SMIRNOV
7713.729 In reply to 7713.728
Seems node Octane is not include in this last Opus !
Must we add something from a previous post from the "deviant thread"?
Else new lang.js for French Update ;)
OK i have the Octane point in extensions from the previous "deviant" post but not the "logo" Octane on the node!
EDITED: 17 Dec 2017 by PILOU
7713.730 In reply to 7713.728
Hello Max!
Thanks a lot for this new update!
I moved NE to my "appdata\Roaming\Moi" and all works fine (on Windows 10 Pro)
@You : "...added: initial node icons support..."
Wow! Much appreciated :)
But...how can I display the icon ? Where the icon files must be placed ? is there a naming convention for the icon files ?
7713.731 In reply to 7713.728
Hi Max,
>> fixed: knob/slider trackpad scroll error <<
I got so excited reading this, because I assumed that you must have tested interfacing with a trackpad.
But the same interfacing issues persist: Zooming & panning in NE interface work only intermittently.
And other odd behaviours where panning is misinterpreted as attempt to move a node's location.
NE on V3.1 all works perfectly.
Show messages:  1-11  …  652-671  672-691  692-711  712-731  732-751  752-771  772-791  …  912
