Parametric design in MoI?
 1-2  …  563-582  583-602  603-622  623-642  643-662  …  903-912
A few items to add to the nodeeditor wiki:
Shift+doubleclick on a node will also open the info panel.
Multiple nodes may be displayed in the info panel by shift+clicking on additional nodes.
There is a rounded rectangle to the left of each node name.
Clicking on the rounded rectangle to the left of the node name, will minimize/maximize the node.
The rounded rectangle is grey for many nodes. If red, the associated js node is likely not installed.
For the output node, the color of the rounded rectangle is an indication of the status of the node.
Like a traffic stoplight, green indicates a favorable setup.
Red indicates a problem. Orange indicates some intermediate state (?)
7713.604 In reply to 7713.603
Hello Brian,
any help is welcome. So please ask Michael to get an account to the wiki. so you can place all the informations directly into it.
Feel free to Change everything you want in it - it should be a living documentation.
Have a nice day
Karsten
7713.605 In reply to 7713.604
Thank you Karsten,
Just sent an email message to Michael, requesting access.
7713.606 In reply to 7713.605
Hi Brian, you're all set up now. Thanks!
7713.607 In reply to 7713.606
Thank you Michael.
7713.608
Nodeeditor v.0.94
- Added initial suport of color schemes. Edit colors.js file to create your own color scheme. You don't need to replace all colors in a custom color scheme, just colors you want to override.
Use custom color scheme name as parameter when you start nodeeditor.
Example: moi.ui.createDialog( 'nodeeditor/index.html?Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
- Added Quartz node (now it works exactly as I planned)
I've not tested it well, so there can be bugs. Waiting for a bugreport.
- Added Edges switch in Output node
- Added mouse wheel support for Knob and Slider nodes (I like it!)
- Added JSON.prettify funcion which affects on nod-files internal structure.
- UI tweaks
- And one more thing..
will be announced later :)) v.0.95 in progress ;)
P.S. Page added http://moi.maxsm.net/item/56/category/3
P.P.S. 18.09.2017 Bug fixed in nodes/basic.js (Edge switcher)
EDITED: 7 Mar 2022 by SMIRNOV
7713.609 In reply to 7713.608
Thank you very much Max for this long-awaited update.
A triple Hip, hip hurrah!
Max is back.
7713.610 In reply to 7713.608
Hi Max.
I was playing for about two minutes with the new node editor and I probably don't know how it should work,
but I'm pretty sure there's a bug regarding the "Edge switch on-off" of the "Output" node.
For what I've tested, when you switch to off and then to on the edges never appears.
Please watch this brief video : http://take.ms/w3kGK
Bye.
Max the return
Message 7713.612 deleted 19 Sep 2017 by JFH
7713.613
Marco, thank you. Bug fixed. Nodeeditor reuploaded. (nodeeditor.v.0.94.2017.09.17.zip -> nodeeditor.v.0.94.2017.09.18.zip)
7713.614 In reply to 7713.613
Thanks!
Bye.
7713.615 In reply to 7713.608
Hi, Max.
Love the mouse support for the slider and knob.
On my system on click of the mouse wheel gives a change of 5% of the maximum value.
Is there a way to change this to give a much smaller change, say 1%?
BTW I've checked in Control Panel and my mouse wheel is set for the minimum change of 1 line.
Mike.
Nice "light blue" cursor.
The quartz node, with high frequency input, really moves the motor rapidly.
Changed the nodebox for motor rod from green to blue. (trivial)
Three+ ways to start nodeeditor94, for "Light" color version. (Somewhat relevant to default "dark" version and perhaps custom colors, and Mod version.)
1. By Shortcut key: (My example keys shown here: Ctrl+Alt+M for Dark, and Ctrl+Alt+N for Light.)
Light version: Ctrl+Alt+N moi.ui.createDialog( 'nodeeditor/index.html?Light', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Dark version: Ctrl+Alt+M moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
2. By using MoI command window: Highlight one of the lines above beginning with moi.ui.createDialog. In MoI press keyboard Tab, Ctrl+v, enter.
3. By CustomUI, (Involves editing, so this is for knowledgeable/experienced users, and are vague, as the difficulty level could vary.):
a. Under ui/customui, copy item 99 to say new item 97 and edit/modify for Light parameters.
or b. Under ui/customui, copy item 99 to say new item 98, edit/modify, and add subfolder link for 3rd party Mod nodes.
EDITED: 18 Sep 2017 by BEMFARMER
7713.617 In reply to 7713.608
Hello Max,
thanks for the update!
I am curious:-)
Have a nice day
Karsten
p.s.: An older and small Problem: While running in Progress and Switching Basic\Extract by RMB to Numbers the node crahes - it seem that the open Input won't be catched.
7713.618
Fantastic job Max!
7713.619 In reply to 7713.617
Hi Karsten,
basic.js line 449 should be: inp = this.getInputData(0, [0]);
Fixed. Thank you.
7713.620 In reply to 7713.615
Hi Mike,
Each step = range/20
interface.js line 134 and 254
change v += delta/20; to v += delta/100;
UPD:
Added dynamic delta adjusting
French Version of the update release ;)
7713.622 In reply to 7713.620
Hi Max.
Only a simple question about update of Project Elephant, in general.
Will you release every further update, big or small, using your moi.maxsm.net web site (Nodeeditor AddOns) ?
I hope so, because in this way everyone can easily get the latest official version,
without the need, as happened so far, to search here and there single files to update our local version of Elephant.
For example, in your last message you have attached the file "interface.js".
if I instead pick the "nodeeditor.v.0.94.2017.09.18.zip" file currently stored into your web site, will I get the latest update of Elephant including this new "interface.js" file ?
In order to make our life easier :) I kindly ask you to publish every updates in your web site or in one single zip file placed everywhere, containing the whole Project Elephant folder.
In this way we can simply unpack the folder and overwrite every old local file with one simple operation.
Thanks again and have a nice day.
Show messages:  1-2  …  543-562  563-582  583-602  603-622  623-642  643-662  663-682  …  903-912
