Parametric design in MoI?
 1-15  16-35  36-55  56-75  76-95  …  896-912
Works fine! Very neat! And very smart when you have 2 screens! Bravo!
French Version of the Install! ;)
The tricky thing is (re) install the Custom UI if not existing! ;)
No Erase All or New?
No Undo ? (When create some nodes)
A very minor default : little flickering when we resize the window ;)
Seems translation possible with some attention to the code! :)
Access to the nodes
Here the Nodes accessible : Maybe I have forgotten something ?
Properties of the nodes
EDITED: 29 Nov 2015 by PILOU
7713.38 In reply to 7713.32
Hi Max,
I'll try to help with documentation.
@Max
In this portion I must translate only red lines : more, less? I am not sure for the "objectlist"...
Generally all words between 2 "" ?
EDITED: 30 Nov 2015 by PILOU
I have this at start but after all works fine! (Maybe an extra translation of something...)
Or maybe the default node that I have erased in previous session ?
And quasi all nodes are now in French! Not so evident! :)
7713.41
Hi Max
Great Job... Wonderful
Your Plug make a quality jump to Moi...
I have a question ;
Can I install the plug NodeEditer , without , before to install
Custom UI in my computer
thanx
al
7713.42
No. You can safely change only "In" "Out" Loft.title Loft.desc
P.S. Don't waste your time. Wait for the beta version.
speedy
>> Can I install the plug NodeEditer , without , before to install Custom UI in my computer
Yes. You need to extract archive to /ui/ directory and then bind "moi.ui.createDialog...." command to any button you want (Options/Shortcut keys).
7713.43 In reply to 7713.41
You dont need custom ui. Put the zip files in the moi ui folder and then make a shortcut with the line of code in the post.
7713.44 In reply to 7713.42
@ Max
Cool to know!
As all is quasi done, I am waiting now the beta! :)
I began an extremely rough initial documentation, which I hesitantly post here. :-)
EDITED: 1 Dec 2015 by BEMFARMER
7713.46 In reply to 7713.42
Hey Max,
Just loaded it and am getting a blank white dialogue window... Have you seen this yet?
Using windows 7. Nothing particularly different from a default install of it.
[EDIT] Please disregard.... I installed the files incorrectly. Got it sorted out....[EDIT]
EDITED: 30 Nov 2015 by BURRMAN
7713.47 In reply to 7713.45
Did a revision of one paragraph of documentation, post 45.
7713.48
Frame node rewritten
Added Rotate object node
extract this archive to /ui/nodeeditor/nodes/
bemfarmer
Thank you!! Great!
EDITED: 7 Mar 2022 by SMIRNOV
Keep the impetuous work! Excellent!
Very cool video explanation!
EDITED: 1 Dec 2015 by PILOU
7713.50 In reply to 7713.49
today I'll add a multilanguage support to this project. Could you make french translation using this form:
"Out" : "Vers",
"Radius" : "Rayon",
"Knob" : "Potar",
"X axis" : "..."
Had a very brief peek at the code to see about trying to code catenary, or something.
(This may be within my capability, after the roof leaks are patched:-)
Searched on the litegraph link and saw a demo. (Non Moi)
http://tamats.com/webglstudio/litegraph/demo/
Several dozens or hundreds of Objects, etc, left to program...
7713.52 In reply to 7713.50
@Max
No problem!
Perfect : I will make that in no time this evening! :)
Like this ;)
"Out" : "Vers",
"Radius" : "Rayon",
"Knob" : "Potar",
"In" : "De",
"X axis" : "Axe X",
"Circle" : "Cercle",
"Sphere" : "Sphère",
etc...
In general it can arrive some problems with accents! (UTF / ANSI)
For the moment seems I must convert to ANSI when I edit the file and resave!
You will post a text(s) file(s) ressource with list with some items with empty second part of line like above
or I must collect myself some words in some existing little files ?
(i am not sure in all cases if it's a real word to translate or a variable or other! ;)
EDITED: 2 Dec 2015 by PILOU
7713.53 In reply to 7713.52
Frenchy Pilou
>>"In" : "De",
>>"X axis" : "Axe X",
Exactly :)
It's ok. Just convert the file to UFT and send it to me.
>>I must collect some words in some existing little files ?
Yes, but you don't need to dig into the files. Just translate everything you see. Order doesn't matter.
7713.54 In reply to 7713.34
Max,
Does this only work on a Mac? I just get a blank screen pop-up on my PC (of course it could be user error :-)~
Michael T.
7713.55 In reply to 7713.54
it should work, check the installation paths.
Show messages:  1-15  16-35  36-55  56-75  76-95  96-115  …  896-912
