Parametric design in MoI?
 1-15  16-35  36-55  56-75  …  896-912
7713.16 In reply to 7713.7
Frenchy Pilou
>> or wait a little for have this inside MOi!
A little? :) I never told that. It will come right after MoI v4, or later, or it will never come at all.
7713.17 In reply to 7713.16
So a big little during a new moment of inspiration! :)
7713.18
7713.19 In reply to 7713.18
Seems you don't drop the affair! ;)
Courage!
7713.20 In reply to 7713.19
In fact I didn't spend a lot of time writing it. I decided to finish the main core script, and then share it with community.
I still do not have plans to write the whole node-system for MoI.
7713.21
Max,
I think there is a real business opportunity here.
I for one, would be prepared to pay for a node-based parametric add-on for Moi3d.
7713.22
This project is very close to alpha release :)
In the last build I added Save/Load functions, node info/edit panel, slider node.
EDITED: 7 Mar 2022 by SMIRNOV
Seems terrific! Pleasure of the coding! ;)
Any functions valuable ?
EDITED: 23 Nov 2015 by PILOU
7713.24 In reply to 7713.22
Hi Max,
I am deeply impressed! Hats off to You!
With respect and Kind regards
Karsten
7713.25 In reply to 7713.22
Unbelievable, this is realy great. Bringing MoI closer to tools like Houdini etc.
Great work Max
Vojtěch
https://vojtisek.artstation.com
7713.26
7713.27
Preview 3
James,
Maybe.. Anyway this script will be free for every MoI user.
Frenchy Pilou
Sorry, I don't understand you question.
guyver
>>it is possible integrate appleseed or similar?
Everything is possible. But I have no plans about it. ;)
Vojtisek, Karsten, Frenchy Pilou, James thank you! :)
7713.28 In reply to 7713.27
Very neat!
@ Max
Just if all functions of the Moi UI will be present on the nodes system! ;)
Another thing : your nodes will be easily accessible for translation ?
Like this for example
EDITED: 25 Nov 2015 by PILOU
7713.29 In reply to 7713.27
It's looking really cool Max, I think a lot of people will be interested in it!
7713.30
It's looking cool indeed, time to parametrize some stairs!
Thanks Max,
Max.
7713.31
Frenchy Pilou
Not every function can be implemented.
At the moment this program doesn't support translations at all. The engine uses names of variables as labels. So, you can't just rename labels.
I'll make multilanguage support later. But now it will be English only.
7713.32
Good news :) Today evening will be first public release of this node-editor.
Btw, could somebody help me with documentation? As you can see, my english is far from perfect, so I'll waste a lot of time if I do it myself.
I definetely need help :)
Suspense! ;)
EDITED: 29 Nov 2015 by PILOU
7713.34
v0.2 alpha (tech demo)
Extract .zip archive to /ui/ directory:
\ui\nodeeditor\index.html
\ui\nodeeditor\core\imgs
\ui\nodeeditor\core\litegraph-editor.js
\ui\nodeeditor\core\litegraph.js
\ui\nodeeditor\core\imgs\*
\ui\nodeeditor\css\litegraph-editor.css
\ui\nodeeditor\css\litegraph.css
\ui\nodeeditor\css\style.css
\ui\nodeeditor\nodes\basic.js
\ui\nodeeditor\nodes\factories.js
\ui\nodeeditor\nodes\interface.js
\ui\nodeeditor\nodes\objects.js
use this command to run the script:
moi.ui.createDialog( 'nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow )
You can run this script using CustomUI addon. Put attached "99 NodeEdit.htm" file to /ui/customui/ directory and restart MoI.
7713.35 In reply to 7713.34
It works, I like the interface also.
Of course the more functions available, the better it gets.
Thank you
Show messages:  1-15  16-35  36-55  56-75  76-95  …  896-912
