CAD capabilities.
All  1-5  6-7
771.6 In reply to 771.5
< also, if i draw a cube in moi, can i export all 6 sides as individual 2d objects from MOI?
Seems yes but you must move each facetts in a same view because you must choose a view before the export!
You can use the function Offset for extract some facetts and after you can move, rotate, as you want etc...your 6 faces in a same view before the export al :)
If you make the export in the 3D view you will obtain some losanges!!!
So use the top, right, front views for have any deformations!!!
771.7 In reply to 771.5
Hi Hightower, well I am really surprised that Mach3 supports all those different formats but not AI or IGES. I would have thought that especially AI would be at the top of their list...
I tried looking around and it seems to be hard to find a free converter from AI.
One thing that would work for sure is either Rhino or Adobe Illustrator.
There isn't any automatic method, but you could do this by selecting the cube and using Edit/Separate to break it into different surfaces, then select the surfaces one at a time and use File / Export to export each one to a different file.
File / Export will only write out the selected objects to the file instead of everything like Save As does.
Show messages: All  1-5  6-7
