guidelines
7706.1
I have discovered guidelines (cool) and implemented them but how can I create them and have them remain visible as I create more of them?
Can I toggle them on and off or clear them if they can indeed be ongoing and visible. Think Abobe Illustrator guideline usage!
Thank you.
7706.2 In reply to 7706.1
Hi Mike, the regular construction line behavior is that they are cleared out at the end of a command, that makes it easier to create as many as you need for a particular point pick without having them stay around and clutter things up.
It is possible though to set up a script on a shortcut key to keep the last created construction line around, there's also a plug-in you can set up which will make a command that you can run to create construction lines and have them stay, the information on that is here:
http://kyticka.webzdarma.cz/3d/moi/#KeepCLine
7706.3 In reply to 7706.2
Ok, and thank you!
