Hi Marv,
> I had that problem. Vectric told me to convert to a another format.
> So I export the dxf into CoralCad and save and use it in dwg format.
Do you mean you had the exact same problem that curves were transferred but just snapping onto those curves was not working how you needed it?
Or was there a problem actually transferring the curves over? If so then that's a different problem.
Some programs will not read "SPLINE" type entities from DXF files, if you run into a program like that, you can change the option in MoI at export time to export curves as Polylines rather than as spline curves, it's the option here:
When you set that you should then get things to go through, but the curves will be converted into a polyline made up of a bunch of line segments instead of staying as a true smooth curve. That's fairly likely to be what happened anyway when you imported and exported from CoralCad.
