Scrambled after 5 min
7700.1
I have to save my work, exit program then restart and reload
This problem has reappeared. Was occasional now every 5 minutes
Yes it has an intel chip set
dell inspiron 15R
win 8.1
DisplayThreadLimit=1
Marv
Attachmentmoi.ini
7700.2 In reply to 7700.1
Hi Marv
Does this happen for one particular file?
Have you tried to do a Video Driver update?
7700.3 In reply to 7700.1
Hi Marv, there seems to be an issue with Intel graphics separate from the threading issue. Right now I don't have a solution for it, but it appears that v2 is not affected and you might try installing an older video driver instead if it used to work better.
I will be trying to investigate it some more and see if I can come up with a solution for v3.
7700.4 In reply to 7700.3
Hello Michael,
I rolled back the video driver to the previous driver edition. That appears to have solved the problem.
In Intels infinite wisdom they screwed up my MOI 3d with an update.
Marv
7700.5 In reply to 7700.4
That's great Marv, I'm glad that you're back running again.
Maybe I will be able to figure out what the current driver is sensitive to. It could be a newly introduced bug that will be fixed with an upcoming driver update.
