wireframe view
7694.1
I'm sure I'm missing something really obvious here, but can you view parts/objects in wireframe display only within MOI3D?
I've been asked to show the dimensions of around 6 parts I've been working on and I'm using the wonderful script by Max (thank you).
It just would be easier to work with a wireframe as a line drawing to purely show the dimensions and then output a pdf. (Searched the forum etc).
Barry
7694.2 In reply to 7694.1
Copy past your 6 views Objects on the same screen : some rotations / mirror
And for the Wire Frame use the Types Button Browser! ;)
EDITED: 31 Oct 2015 by PILOU
7694.3 In reply to 7694.2
Ahh, that's it, so easy, I missed it completely.
Thank you, Pilou.
Purchasing MOI3D has certainly been one of my best work decisions in 2015 and the expertise and helpfulness on this forum is wonderful.
Thank you.
Barry
7694.4 In reply to 7694.1
Hi Barry - yeah MoI doesn't quite have a regular wireframe display mode - that's because it instead has a hidden-line wireframe mode that you can turn on under View > "Display hidden lines", which makes all the wireframe curves and edges visible in a faint dashed hidden line and also accessible for selection as well. So just for getting at the wireframe that does the job rather than a dedicated wireframe display mode.
But there are a couple of other ways to do it - like Pilou shows above if you go the Scene Browser > Types section, you can use the eye icon to either show all Edges only if everything is currently hidden, or to hide all faces if everything is currently visible. Either of those will leave you with edges only being displayed and that will be just like a wireframe view.
Also if you need to frequently switch in and out of that, there are some various wireframe display related scripts you can put on keyboard shortcuts here:
http://kyticka.webzdarma.cz/3d/moi/#ToggleHiddenLine
7694.5 In reply to 7694.4
Will install the wireframe display script as well. I can see that being very useful, especially when selecting small detail work.
Thanks, Michael.
Barry
