Surface Pro 3
All  1  2-8
7686.2 In reply to 7686.1
Oh, and I am running extended displays. I tried it with duplicated displaces on a lower res, but ran in to similar issues.
Thx
7686.3 In reply to 7686.1
Hi Dave - if you turn off multithreading in the display engine it should fix that, it seems that the video driver with the surface 3 is sensitive to multiple threads being used.
See here for how to set it: http://moi3d.com/forum/index.php?webtag=MOI&msg=7385.3 , you need to edit moi.ini and set DisplayThreadLimit=1 in there.
Please let me know if that improves things for you.
7686.4 In reply to 7686.3
I made the edit and checked for driver updates as well (it turns out I had the latest version). I'm still having the problem. I'm able to duplicate it. MOI seems to work great until I draw 2 curves and then join them. If I try any sort of mirror or copy command afterwards, that's when I run in to trouble.
As a side note, it's interesting that after I have the issue, IE slows for a few moments down to the point where I am typing this post much faster than the characters are appearing on the screen. However, if I test other programs (word, windows explorer, Firefox, powergrep, etc) they seem to respond properly. I checked task manager and it seems to show no resource issues.
Any more thoughts? :-)
Dave S
7686.5 In reply to 7686.4
Hi Dave, sorry no other ideas on what might be going wrong. It sounds probably video driver related though.
I would have thought setting DisplayThreadLimit=1 in moi.ini would have got you going, sorry that is not the case.
If you've already purchased MoI and are not able to use it please let me know and I will send you a refund.
7686.6 In reply to 7686.5
Michael,
No worries. I've been onboard with MOI since 2010 and it's too awesome to let a driver issue stop me. I'll just put it on my desktop for a while and check back with the driver issue at another time.
Thanks for the help.
Dave S.
7686.7
Hey Michael,
Upgrading my surface pro 3 to windows 10 seems to have fixed the issue. I think it updated the driver because the driver date looks a couple of months newer. I wonder if the driver installed by windows 10 would work on 8.1 for those other surface pro users. anywho... It works in windows 10 ... : )
DS
7686.8 In reply to 7686.7
That's great news DS!
Show messages: All  1  2-8
