Borromean Seifert Surface
All  1-2  3-9
A complex surface indeed!
Does the thickness is working on it ?
7682.4 In reply to 7682.3
Hi Pilou
After planar, Moi "Types" indicates the presence of a solid.
There is a small tetrahedral solid, located by a small hole defect in the borromean-unorientable model.
I'll have to check the points involved, or fix it manually.
I do not have the skill to thicken the surfaces.
In the Costa discussion, Stefan mentions "LS3 Loop subdivision," Meshlab, "Dual remeshing," ZBrush-Z Remesher, and Fusion360 T-Splines.
7682.5 In reply to 7682.4
Restored two missing triangles in version borromean-unorientableONE. Solid generated after planar and join is now gone.
Corrected version *TWO.csv attached.
Corrected again, 11/1/2015
EDITED: 2 Mar 2021 by BEMFARMER
7682.6 In reply to 7682.5
script: /* Highlight naked edges */ selects the 3 boundary ellipse polylines.
Subdiv_Beta9 does not work on the unorientable model.
This is the Borromean Tetrahedral center surface evolver csv triangle file.
SubDivBeta9 on unjoined planar triangles, at 125.
This script, _ImportTrianglesCSV, is a modification of the P_ImportSTL script., and is about 100 times faster than the previous triangle import script.
It imports one specific kind of file. The files came from surface evolver program.
The CSV file contains only a list of triangle vertices, comma delimited.
There is one vertex per file line, with coordinates x, y, z.
Three file lines defines a triangle by its 3 vertices.
An alert message displays the number of triangles imported. It could be commented out, or maybe have a checkbox?
The total number of vertices in the file should be a multiple of 3.
Otherwise, the last triangle will not be created by loft.
Even though the triangles may be loaded and displayed, failure of the alert message to appear indicates a problem with the file.
This may occur if the last triangle is missing 1 or 2 vertices.
It may also occur if there are extraneous delimiters.
It may be possible to incorporate the delimiter selection of _ImportPointFile script?
Two more soap films.
Show messages: All  1-2  3-9
