Borromean Seifert Surface
All  1  2-9
Edit: BorromeanSeifert .3dm of 6.5 MB deleted. No one downloaded it.
Uploaded borromean-seifert csv file of 193 kb.
EDIT: Deleted borromean-unorientableONE csv file of 191 kb, due to two missing triangles. Replaced with version TWO in later post.
Also uploaded the ImportTriangleFile script, which is a special purpose script to upload the two csv files above.
The files consist of vertexes of triangle corners. Each line is a vertex (x,y,z). Three sequential vertexes make a triangle.
So a lot of the vertexes are duplicates. The source files are very fast in WebGL memory. These two files are striped down.
There are no normals. The 3 boundary ellipse polylines are not included, but can be selected from the edges and re-created.
A modification of ImportPointFile script, with some LineWeb code grafted in, the ImportTriangleFile script is slow,
so it may have some incorrect code (?), but it works. ObjectList methods for the script were not successful, more study needed :-)
Please allow at lease 5 to 30 seconds after pushing the Done button, for the triangles to load, and for the script to close, on a fast computer.
Now to try saving in Moi as conventional obj files.
Looks like the point import option is broken, but the points can be imported with the ImportPointFile script.
The points will have many duplicates...
EDIT: See post 8 for updated _ImportTrianglesCSV script.
EDITED: 2 Mar 2021 by BEMFARMER
A complex surface indeed!
Does the thickness is working on it ?
7682.4 In reply to 7682.3
Hi Pilou
After planar, Moi "Types" indicates the presence of a solid.
There is a small tetrahedral solid, located by a small hole defect in the borromean-unorientable model.
I'll have to check the points involved, or fix it manually.
I do not have the skill to thicken the surfaces.
In the Costa discussion, Stefan mentions "LS3 Loop subdivision," Meshlab, "Dual remeshing," ZBrush-Z Remesher, and Fusion360 T-Splines.
7682.5 In reply to 7682.4
Restored two missing triangles in version borromean-unorientableONE. Solid generated after planar and join is now gone.
Corrected version *TWO.csv attached.
Corrected again, 11/1/2015
7682.6 In reply to 7682.5
script: /* Highlight naked edges */ selects the 3 boundary ellipse polylines.
Subdiv_Beta9 does not work on the unorientable model.
This is the Borromean Tetrahedral center surface evolver csv triangle file.
SubDivBeta9 on unjoined planar triangles, at 125.
This script, _ImportTrianglesCSV, is a modification of the P_ImportSTL script., and is about 100 times faster than the previous triangle import script.
It imports one specific kind of file. The files came from surface evolver program.
The CSV file contains only a list of triangle vertices, comma delimited.
There is one vertex per file line, with coordinates x, y, z.
Three file lines defines a triangle by its 3 vertices.
An alert message displays the number of triangles imported. It could be commented out, or maybe have a checkbox?
The total number of vertices in the file should be a multiple of 3.
Otherwise, the last triangle will not be created by loft.
Even though the triangles may be loaded and displayed, failure of the alert message to appear indicates a problem with the file.
This may occur if the last triangle is missing 1 or 2 vertices.
It may also occur if there are extraneous delimiters.
It may be possible to incorporate the delimiter selection of _ImportPointFile script?
Two more soap films.
Show messages: All  1  2-9
