You can input a percentage sum now, MoI has a built in math function. For example if you need to increase 25mm by 2.5% you just input 25*1.025 and MoI will calculate it for you, 25.625mm in this case.
Hi Stav, Danny understood your request better than I did - the built in math formula calculation that Danny mentions above is available in any numeric input field in MoI so that can work anywhere without the need for an additional field in the UI.
Hi Stavros
What are you printing them on to cast ?
I have a Kevvox resin printer and I do not scale at all , I just draw it the size I want exactly and cast it from that .
Are you making masters that are being vulcanised and wax injected ? hence the 2.5% shrinkage.
This I printed as drawn
