Percentage field in Offset request
All  1  2-6
7678.2 In reply to 7678.1
Hi Stav, could you maybe explain your request a bit more - I'm not sure what the percentage would be based on, I mean a percentage of what value?
7678.3 In reply to 7678.1
Hi Stavros,
You can input a percentage sum now, MoI has a built in math function. For example if you need to increase 25mm by 2.5% you just input 25*1.025 and MoI will calculate it for you, 25.625mm in this case.
7678.4 In reply to 7678.1
Hi Stav, Danny understood your request better than I did - the built in math formula calculation that Danny mentions above is available in any numeric input field in MoI so that can work anywhere without the need for an additional field in the UI.
Thanks Danny!
7678.5
Hi Stavros
What are you printing them on to cast ?
I have a Kevvox resin printer and I do not scale at all , I just draw it the size I want exactly and cast it from that .
Are you making masters that are being vulcanised and wax injected ? hence the 2.5% shrinkage.
This I printed as drawn
cheers
shayne
7678.6 In reply to 7678.5
Hi Shayne,
Stavros didn't mention 2.5% I just made that figure up to show in the example :)
Show messages: All  1  2-6
