Hi Stefan - I tried one version attached here with erasing the cutout by drawing the same kind of rectangle that you had done previously for the boolean intersection, then extruding it just like you had done in your steps (because boolean union does not auto extrude 2d profiles like the difference or intersection does), then doing boolean union and I seemed to get an ok part with the cutout entirely removed.
Are you trying to do something like only restore some upper portion of the cutout while leaving some of the inner structures on the inside bottom intact?
Anyway the attached file has the cutout removed, if that's not what you need I'll probably need some more information.
