Trail Version will not start up.
All  1-6  7-8
7663.7 In reply to 7663.6
Hey,
Did some research on the exporter instead(didn't have time to mess with firewall). People have said good things about it, so I decided to purchase Moi a couple days ago.
The exporter works great! Still trying to optimize settings for Modo/ Octane Render but so far quads and triangle export works most consistent. I would like to use the ngon export but there was 1 distorted polygon left near the edge of a boolean'd surface with complex curvatures.
Thanks for the help again and great software.
7663.8 In reply to 7663.7
Thanks Dan, I'm glad that the exporter is working well for you!
N-gon export should work well for Modo but for Octane you'll probably need to use Quads & Triangles instead - some rendering programs don't deal with complex n-gons very well and have problems converting them to triangles. If you run into that you'll have to use Quads & Triangles export instead.
Show messages: All  1-6  7-8
