Wrapping a texture mesh around a cylinder?
All  1-3  4-6
7647.4
Thanks guys.
Getting a bit closer. I re-did the mesh for a much closer end result to what I was thinking. I did manage to get the flow command to work with some extra experimentation and wrapping around half a circle+mirroring the result.
Still some strange issue with edges overlapping, but hopefully I will figure out what is causing the surface alignment issue.
Size: 195.6 KB, Downloaded: 114 times, Dimensions: 718x687px
7647.5 In reply to 7647.4
Unwrap of a circle can produce a line of the proper length to use in the input. So either the line or a plane of the lines length is useful.
<< Still some strange issue with edges overlapping
For avoid that make first a single Source first without overlapping itself !
Show messages: All  1-3  4-6
