moi won't start with double-clicking a 3dm file
All  1-8  9-11
7646.9 In reply to 7646.8
No problem Wim - if you happen to run into it again please capture the full path that the file is in so I can try to test it.
Thanks, - Michael
7646.10
I think I nailed the folder naming problem.
1. make a folder named Test (or any other name)
2. make a folder named Test 1 (or same name as above, but with a SPACE and something else behind it, anything)
3. put a 3dm file in the second folder
4. doubleclick this file
5. file not found.
6. remove the space after the first word from the foldername, and it works.
the logic I think is that MoI searches for the path, but first encounters the first path with that name uptil the first space it encounters, and does not find the file there.
I can reproduce it on os 10.8.5 (macbook pro) and 10.10.5 (mac pro)
wim
7646.11 In reply to 7646.10
Hi wim, thanks for figuring out exactly what causes this. It looks like it's a bug in Wineskin, wineskin is not putting quote " " characters around the command line parameters that have spaces in them which will make MoI think that they are separate parameters rather than one long one.
I don't think I'll be able to do anything about it for v3, but for v4 I should be able to fix it since Wineskin won't be used anymore.
Show messages: All  1-8  9-11
