Caution in upgrading to El Capitan
 1-17  18-24
7643.18 In reply to 7643.17
Go to Applications in Finder, then right click on MoI and then select "Show Package Contents".
If you have not installed MoI to Applications, then you will need to find the "MoI v3.app" and follow the above instructions
Martin
(TpwUK)
7643.19 In reply to 7643.18
OK! It's working now!
I was looking for the package inside XQuartz and not inside Moi3D...
Thanks for you help.
7643.20
Hi Guys,
Here is a (preliminary) list with working and not working apps in El Capitan:
http://forums.macrumors.com/threads/os-x-el-capitan-working-not-working-apps.1890772/
Not Working
XQuartz (requires rootless be turned off to install)
7643.21 In reply to 7643.19
@javier,
That's great javier, yes that's correct the wineskin.app where you go to adjust the setting is inside of MoI, I'm glad you are working now.
7643.22
yes but the maximized viewport is bugged....
7643.23
Hey guys,
I have a bugged viewport too.
Everything is fine when I am in Split view but when I select 3D view . I get a 3d view hidden by top-front-right.
Here is an image:
http://i.imgur.com/7eu2v0e.png
Did anyone manage to fix this?
7643.24 In reply to 7643.23
Hi crobotok, it's fixed in the version 3.1 update, you can download the updated version by putting in your v3 license key here: http://moi3d.com/reinstall.htm . Once you switch to using version 3.1 instead of the original version 3.0 that problem should be solved.
Show messages:  1-17  18-24
