Couple of questions?
All  1  2-6
764.2 In reply to 764.1
Hi Paul,
re: Area zoom on a shortcut key - try this as the command:
script:var v = moi.ui.getActiveViewport(); if ( v ) v.interactiveViewChange('zoomarea');
That should trigger the area zoom on the viewport that the mouse is over.
re: #2 grid size label -
Change the "binding0" there to just "binding" - in the last beta I cleaned up some of the syntax a bit, this was one of the changes. Once you change that, the grid size should show up in there and be editable, but there isn't currently any way to make a numeric text input box like that not get activated when you push the decimal point.
But if all you want is a readout, then that is possible by using a different element to just display the grid size, it has to be set up to have the "binder" on it that handles reflecting properties back and forth, here's a minimal version:
<moi:PaletteHeader>
</moi:PaletteHeader>
<moi:PaletteBody>
Grid size: <span style="behavior:url(#default#PropertyBinder);" binding="innerText < moi.grid.size">
</moi:PaletteBody>
In this case the binding="innerText < moi.grid.size" sets up a one-way binding, where changes in the moi.grid.size property will funnel in and update the span's innerText property.
If I understand you right, this should get you set up!
764.3 In reply to 764.2
Great! That looks like it should do it. You're right, all I wanted was a grid size readout, I'll try your suggestion out tomorrow. Thanks-- Right now it's late, need sleep..........:)
Paul
764.4 In reply to 764.3
Hi Paul, time for me to go to sleep too. I just noticed one typo above, that <span> should have a closing </span> after it.
764.5 In reply to 764.1
Hi Paul, quick note - I had to revert this one syntax change so in the next beta you'll have to switch your little grid readout thing to say binding0="..." instead of binding="..." .
764.6 In reply to 764.5
Thanks Michael,
I'll change that when I upgrade to the July 25 beta, grid label working just fine.
A note on the scripting problem some people are having - no problems here, running
XP sp2, IE6. Everything working as advertised! Thanks again,
Paul
Show messages: All  1  2-6
