Most images made with DeepDream looks boring, because people use online generators with standard settings, like Pilou shows. If you download Deep Dreamer from Github you can archive quite good results and you can use also use the libraries from MIT and Berkeley and not only the standard one from Google.
Here are some images i made with with Deep Dreamer:
With the same subject from Leonard and with the "on line" (because install the prog is not so evident and speedy) :)
I prefere wait the "all in one" by Google in some times :)
