"Puzzle Creating"
7619.1
many greetings to all MOI Forum members.
I want to create a "Voronoi-Puzzle".
No problem with the great Voronoi-script.
But after boolean "merge" I have to move the single objects a little bit to the outside to become a small gap between the objects.
At the moment I do this by hand.
I wonder if there is a possibility to automatically move the objects to the outside to become a 2mm gap.
Frank
Press TAB then write ExplodeMove on the early process! (All plugins by Max Smirnov! Except ExplodeMove by Michael! ;)
(don't make the "Delconers" ! ;)
_Voronoi > Clear Points > Select All> Plane > Trim> Select Edges> Move them somewhere > Join > _Delcorners>ExplodeMove.
You can also use the "_Fatlines" script as triming knife! ;)
Just 4 corners to trim , not a big deal :)
EDITED: 17 Sep 2015 by PILOU
7619.3 In reply to 7619.1
Hi Frank,
The closest thing to this would be ExplodeMove like Pilou mentions:
http://moi3d.com/3.0/docs/moi_command_reference10.htm#explodemove
But the objects will move outwards from their overall bounding box center, it won't necessarily move them with a uniform gap between each piece. So to get a uniform gap you might need to use the manual movement that you've already been using.
7619.4 In reply to 7619.3
Hi all,
thank you very much !
The ExplodeMove is exactly what i have searched.
A uniform gap would be nice, but not necessarily needed.
Frank
7619.5
Hi Frank,
check this example
EDITED: 7 Mar 2022 by SMIRNOV
7619.6 In reply to 7619.5
Good workflow...
Thank you Max !
7619.7 In reply to 7619.5
Hi Max,
what's the name of the font you used in the example?
7619.8 In reply to 7619.7
Hi Martin
it's GOST 2.304-81 font (common font used in russian design documentation)
http://moi.maxsm.net/share/GOST2.304-81.zip
7619.9 In reply to 7619.8
Thank you Max!
-Martin
7619.10 In reply to 7619.8
Thanks Max for sharing! I like that font :-)
Cool the trick of the "Scale" ! Avoid some manual corners trimings! ;)
