Hi Burr - unfortunately that's a fundamental limitation of .obj files. OBJ format was designed maybe around 1990 or so, it basically predates the use of unicode and only supports plain ascii characters.
So that's just how .obj files work, they just can't contain unicode characters in them.
I do not know of any way to address it since it's a limit inherent in the file format. If you need every object name or style name character to come through into .obj format you would need to avoid having unicode characters in your names, sorry.
It's amazing what you learn everyday, if you didn't mention this I, and probably many others, wouldn't of known what an Okina was and the fact that this little symbol is part of the Hawiian alphabet.
Hey Danny,
Sure! You'd be surprised at how many people even here don't really know about it.... Every year we have contractors have to redo some big project because someone used an apostrophe in it's place...
Right now, the Hōkūleʻa is finishing up the longest leg of the worldwide voyage. My childhood friend Bruce is the PWO Navigator on this leg.
i tried it too with MoI and it exported nothing under OS X. Then i tried it with Shade and it exported fine as .obj. Once the .obj was exported i used Text Wrangler to add the name manually in the o section and re-imported into Shade, which then showed the proper .obj name of the object in it's Browser.
Edit: the .obj file name does not translate, when uploading to the forum.
