Select Loop ?
All  1-2  3-7
here the script! ;)
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
7611.4 In reply to 7611.3
>>here the script! ;)
Is already present in v3 as Shortcut Key, or not ?
-EDDI
7611.5 In reply to 7611.4
I don't see it! :)
7611.6
Ok great that's for loop and script works :).
Any chance to get "path" working also i.e. i select first and last edge and hit path script to automatically select all in between ?
Lewis
www.lewis.tomsoft.hr
www.ram-studio.hr
Skype - lewis3d
7611.7 In reply to 7611.6
Hi Lewis,
Sorry no, there's not any way currently set up to do that. Usually you would just make a window selection to grab the set of curves you need.
A couple of problems with a path selection mechanism like you are describing is that it would need to search through all curves in the model which is potentially time consuming on a heavy model and also if there are branches in the path that adds another thing it would need to deal with.
For the edge select loop see here for some demos on how to use it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
Show messages: All  1-2  3-7
