Select Loop ?
7611.1
Hi !
Is there a way in MOI to select loop or even better path of edges ? Like i want to click first edge and last edge (on a sensible path) and then MOI selects all in between automatically afte ri execture "path" or "loop" command? I find it tedious to make fillets on some models when i need to click one by one edge. I see only Select All, Deselect all and Invert in selection tools ? Woudl be nice to have "Select Path" or so.
Lewis
www.lewis.tomsoft.hr
www.ram-studio.hr
Skype - lewis3d
7611.2 In reply to 7611.1
Select two or more adjacent edges and press button L (Is under Options --> Shortcut Keys)
EDITED: 12 Sep 2015 by EDDI
here the script! ;)
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
7611.4 In reply to 7611.3
>>here the script! ;)
Is already present in v3 as Shortcut Key, or not ?
-EDDI
7611.5 In reply to 7611.4
I don't see it! :)
7611.6
Ok great that's for loop and script works :).
Any chance to get "path" working also i.e. i select first and last edge and hit path script to automatically select all in between ?
Lewis
www.ram-studio.hr
Skype - lewis3d
7611.7 In reply to 7611.6
Hi Lewis,
Sorry no, there's not any way currently set up to do that. Usually you would just make a window selection to grab the set of curves you need.
A couple of problems with a path selection mechanism like you are describing is that it would need to search through all curves in the model which is potentially time consuming on a heavy model and also if there are branches in the path that adds another thing it would need to deal with.
For the edge select loop see here for some demos on how to use it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.22
http://moi3d.com/forum/index.php?webtag=MOI&msg=3112.32
