Vojtisek's work
 1-9  10-29  30-49  50-56
7602.10
Hi All,
I think that this Mike's post http://moi3d.com/forum/index.php?webtag=MOI&msg=5470.1 is a very nice example of endless possibilities of fantastic MoI :-)
For organic surface modelling in MoI it could be useful some script like "Select points under (freeform) curve" or polygon selector which allow select non-rectangle group of control points.
Mik
7602.11
thanks all for comment and good discusion.
First of all, I'm very glas you like it. I have to say speed is where MoI rocks. I'm long time maya user, but this will take me a lot longer, when I have to do it in subd I mean the hard body of the gun.
I also agree that organic shapes are better un subd workflow, or sculpting.
What I meant was the grip - it's organic, but also technical/ design prop - not anything alive, so it can be handle in MoI too.
I think next time I will be capable of doing it fully in MoI.
In this case - when I export hipoly obj, it's prepared for zbrush pass or normal map baking for game lowpoly model.
I worked with nurbs in maya years ago, and sometimes I'm using them today too - for parts of vehicles or models, where I need precise flow, and them convert them to poly and continue
Thanks for feedback, will post here final model when it will be done.
Vojtěch
https://twitter.com/VojtechLacina
7602.12 In reply to 7602.9
Hi Andrei,
> Basically for me was very hard to dig into SubD I spend about 1 year till I totally dig into it.
I certainly have never said that SubD modeling is "easy" - it can definitely have a substantial learning curve, and certainly a longer one than the one for NURBS modeling where you're working with mechanical shapes.
This lower learning curve is a big thing that makes MoI a useful companion tool that you can use alongside other software. But this learning curve advantage will be lost if you stubbornly try to use MoI for projects where it is not the right kind of tool.
There are also different kinds of "organic" models, it's true that in certain kinds of cases it's more feasible. But if you try to use NURBS for modeling a human face or something like a hand with branching structures, it's particularly not a good fit.
Your particular case of gun handles most likely do not have the kinds of things like sudden changes in detail like around the corners of eyes or mouths or branching structures like limbs and fingers which become extremely difficult to do well with NURBS surfacing. Sub-d modeling allows you to connect up faces in a more arbitrary manner and provide very localized detail, when you try to do that with Loft it's difficult to avoid the rectangular nature of the loft and often times having tangency applied to your loft just over constrains it more, it doesn't provide the arbitrary topology and ability to refine a specific spot of the model with more points like you can do in sub-d modeling.
To a lot of people the word "organic" will mean things like faces and monster bodies and things like that, not necessarily "industrial design" type forms.
So a lot of people reading your advice of something like "oh yeah you can do organic modeling using NURBS" might try to use it to do an organic character model and then get frustrated that it does not work well for that.
Of course I would like to add in more functions for surface continuity for MoI in the future, it would help for certain kinds of things. But it will not suddenly turn the NURBS toolset into a total "organic" toolset able to do any kind of organic shape that sub-d modeling can do. Try to make a face or a hand in Alias and you will see that in action. You will have a lot of difficulty finding tutorials that show how to do it - you could find them 15 years ago when sub-d modeling was not available (that's when character modeling was also done in NURBS), but not anymore since sub-d is just inherently better at doing those kinds of shapes.
A lot of times if you're worried about making a patchwork of NURBS surfaces with continuity, it's really a sign that your project would have been better suited for sub-d modeling. That's why it has not been a focus for MoI as of yet, it just makes more sense for MoI to be focused on getting the "most bang for the buck" and trying to make a lot of the model happen through 2D curve drawing and booleans. For mechanical models this approach is very fruitful. Trying to focus early on, on the most difficult and finicky type of NURBS modeling (patch-by-patch surfacing) just did not make as much sense since it would not benefit as many people as something that could handle mechanical models without needing to be a mechanical engineer.
7602.13 In reply to 7602.12
Yes, you are right I must say that under word organic I mean only things that are made by people not by nature. I just never created characters so I use this meaning by default.
Sure creating things like characters with Nurbs is not good way to go. Now people for high poly characters and other nature objects use sculpting software most of all.
www.samardac.com
7602.14 In reply to 7602.13
Very interessting discussion! May I ask a question? What kind of ("state-of-the-art") workflow is the best for this kind of object:
Thanks!
7602.15 In reply to 7602.14
I assume that it was made with Z-Brush. If you satisfied with quality of this model use ZBrush.
7602.16 In reply to 7602.15
Z-Brush? I thought this is a "sculpting" software for organic objects and not for hard surface creation? Now that I have watched some videos: It`s like working with "digital" clay...
Since I have no talent for this kind of artistic sculpting:
Are there "CAD"-workflows for creating models like this?
There are a lot of panels, panellines, holes and other hard-surface type features that should be easy to create with CAD software. And isn`t the whole model a typical "hard-surface" model?
7602.17 In reply to 7602.16
Yes, this is zbrush. Zbrush powers are not just in sculpting, but also in cutting geo etc.
For zbrush hardsurface I highly recomment this truck tutorial series from Kirill - it's worth the money
https://gumroad.com/kirillchepizhko
Vojtěch
7602.18 In reply to 7602.16
The only problem why you can not make it with MoI is that it has some organic transitions in base shape, that will be very hard to reproduce with MoI. All other stuff in general can be made with MoI without any problems. If you want to use cad software for this, you can use that, that supports SubD or Surface modeling like SolidWorks, Rhino, Inventor, Alias, SolidThinking, Fusion 360, Simens NX, Creo Parametric... As you can see there are lot of them so check what is for you.
7602.19 In reply to 7602.17
Thanks for the link. But what about using CAD-Software like Moi? ZBrush is (how should I put it) too "artsy" for me; I am more of a CAD and tech guy...
Or is ZBrush really better for complex hard surface models? I thought the contrary: CAD-like software for hard surface models and ZBrush or 3dCoat for organic things like humans, creatures etc. (And I am only interested in building hard surface type models).
7602.20 In reply to 7602.18
Thanks, Andrei! Your post didn`t show up when I was writing the previous reply...
7602.21 In reply to 7602.20
Gill,
ZBrush is for organic stuff first of all, but it has tools that allows you to create hard surfaces too. But result is far away from ideal. Quality of organic surfaces are even worse then from polygons.
It is good for games because in games you will see only low poly, so no need for superb quality, or it is good for intermediate quality render of hard surfaces.
If for example you create some close render of this model you will see how imperfect are surfaces, I can see all that artifacts even from this render.
So if you want superb result use Cad.
If MoI had continuity(tangent) options in tools you could made this model without problems in MoI.
www.samardac.com
7602.22 In reply to 7602.21
Thanks Andrei,
thats very helpfull! Anyway, I will buy MOI. I used the demo for a month now, made some not to complex hard surface models and it was great to use. The snapping for example is extremely well-thought-out and easy to use!
The only problem is that I have no idea how to make more complex models like the pictured "spaceship".
I guess I will also have to try, learn (and buy) some other CAD programs...
7602.23 In reply to 7602.22
Gill, you can simplify base shapes of this spaceship and you will be able to replicate it in MoI, just use Loft for that base shapes, check here I made a lot of tutorials about that forms: http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.1
All other stuff of this spaceship is not a problem for MoI.
If you are going to try other software, you can start from SolidWorks.
7602.24 In reply to 7602.23
Gill, I just remember I made about year ago tutorial about space ship, it will be usefull for you beacuse I show there how to make that base shapes.
ZBrush has now a cool "Zmodeler" ;) + some tools ArrayMesh, NanoMesh, QMesh : you can make some things ;)
EDITED: 9 Sep 2015 by PILOU
7602.26 In reply to 7602.22
Every complex model is made from a lot od smaller parts.
Zbrush is superb for quick sketch what you have in head, like taking a simple pen and drawing a concept. Then it depends what you need. If game model or clean model for render, you need to retopo it.
If it is just for static render or design, you can go with decimated geo from Zbrush and polypaint it or use some box uv mapping and then paint it in some other program.
Zb is little bit hard to get at the beginning, MoI is super fast to learn, have very simple ui and powerfull tools.
Similar to Zbrush is Mudbox or 3dcoat - they have more 3d program UI, but ZB have a lot more abilities and most designers use Zb. In big productions Zb is standard.
So, complex models are realy not software dependent - it's about deconstruction what you model, think about separation to smaller and smaller parts and then detailing them.
Start from big shapes and going to smallest one.
I saw people are doing product designs in both - zbrush, nurbs modelers and even polymodelers. Software is secondary, idea is most important :)
Vojtěch
7602.27 In reply to 7602.14
Hi Gill,
Often times vehicles land in a sort of gray area between organic and mechanical, and that makes it not quite so fixed that one specific modeling technology is the automatic best fit for that. You would probably want to use whatever feels most comfortable for you.
The model you show there is tremendously detailed and complex, and so it will involve a very substantial amount of work to make it, no matter what tool you are using.
MoI itself is focused on the idea of making it super quick, fluid, and easy to do simple mechanical shapes. Your model there is by no means a simple mechanical shape and so it's not a direct fit for the core idea behind MoI but it still would be possible to pursue it with MoI if you were to stick with the project for an extended period of time.
7602.28
Something to consider to speed up modeling in MoI is to avoid filleting every single hard edge and use a rounder edge shader in your 3d application.
What I would called 'cosmetic' fillets (very small radius) can easily be handle that way.
It simplify models a lot, and help for further editing.
Depending of your render engine, it's a method that can even work for normal map baking.
When looking at those spaceship models (really amazing job), to get this amount of complexity, we probably need a better sub-object management (groups).
A really amazing concept are Shutline in Rhino :
https://www.youtube.com/watch?v=V_5oO9ehmoo
The workflow is super cool, non destructive and could help a lot to create those SF paneling details.
But it's some sort of 'post meshing' effect, and seems to create easily lots of nasty shading glitches too :(
I can only dream about a enhanced version of this concept in MoI, but I'm affraid it's probably 'too specialized' to fit in MoI toolset.
7602.29 In reply to 7602.28
Hi PaQ,
Yes, kind of... But it also fits in well with the overall strategy of "make things happen using 2D curves" which does give a lot of weight on the positive side of working on it.
That existing one in Rhino does indeed work just on the mesh output and not directly on the real NURBS model, and it can tend to get confused if there's any kind of irregularity or mixture of large and small polygons right in that particular area.
If I were to try it in MoI I guess I'd probably be more likely to try making real NURBS geometry with it rather than only trying to modify things at meshing time... That would generate heavy real geometry but also would be likely to be more robust and not generate glitchy results as much either though. Maybe at some point with a deeper history mechanism you could temporarily turn off that step in the history and let the model recalculate without those in it and avoid the heavy geometry problem that way.
There are still other areas for 2D curves interaction with solids that will likely take priority over this though, like "depth limited" booleans with 2D curves.
Show messages:  1-9  10-29  30-49  50-56
