Tessellation of a generic surface
7601.1
I would need to generate the tessellated version of a generic surface, I tried to implement it by myself but without results :p the output should be a joined surface made of quads following an average.
Is it too much to ask for an inverse subD script?
Regards,
Max.
EDITED: 7 Sep 2015 by WASTZZZ
7601.2 In reply to 7601.1
Result will be not the same than
Export as OBJ with only QUad+triangles
Import OBJ (_import OBJ by Max)
_subdiv_beta6 by max
= only quads ?
Hum... seems there are some triangles :)
EDITED: 7 Sep 2015 by PILOU
7601.3 In reply to 7601.1
Hi Max - tessellating a generic trimmed surface to quads is a quite difficult task. It involves placing quads initially along trim boundaries and then trying to grow or shrink them across the surface and dealing with a lot of issues when different growing boundary sides crash into one another. It's something that I'd like to attempt in the future but will require quite a lot of work to do very well.
Then if you're actually looking for _planar_ quads instead of just any quad with its 4 corner points on a curved surface (making them normally slightly warped and not planar), that's another pretty entirely different thing as well. For that I'd recommend paneling tools in Rhino, that is a specialized toolset for doing planar panelization.
7601.4 In reply to 7601.3
Thanks Michael.
Even if the polygons were warped it would be fine.
Actually I did want to try and implement some sort of simple paneling tools for moi, and yeah tessellation is the first task to do. I did a study over the algorithms though.
M.
