Voronoi Chair Tutorial
All  1-9  10-17
7596.10
an amazing chair design and amazing skills chipp.
Thank you for sharing.
[Denis]
| Carrara Pro 8.5 | Cinema 4D Prime R15 | CorelDraw X6 | Moi 3D v2 | Lightwave 3D 11.6 |
| My work |
Maybe no use of Illustrator ? :)
7596.12 In reply to 7596.11
Yes, I saw your very creative use of Rebuild with no corner points in a previous thread and thought to try that. Great idea!
7596.13
It will be better to use DelCorners script ( one of the first my scripts, by the way :)
Voronoi, Select rectangle ->Planar, Select all -> Boolean merge, Delete lines, Select all -> Separate, Select edges -> Join -> Rebuild (tolerance 1), DelCorners
This is updated version of the script
EDITED: 7 Mar 2022 by SMIRNOV
Cool tricks! _Delcorners is excellent!
I don't use the same exactly way than your (not rebuild here) but use your _Delcorners and ExplodeMove of Michael for more possibilities of placement variations ;)
_Voronoi >> Kill Points >> > Select All>> Planar >> Trim >> Select Edges >> Copy Move them somewhere >> Join >> Delcorners>>ExplodeMove
EDITED: 9 Sep 2015 by PILOU
Works like a charm!
All fantasy are possible! :)
Voronoi, Delcorners, Flow
7596.16
7596.17
Show messages: All  1-9  10-17
