Made With MoI
All
1-4
5-9
hep
6 Sep 2015 (5 of 9)
7595.5
Wow, very nice.
How did you ever cast those pieces from the print?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
AlexPolo
6 Sep 2015 (6 of 9)
7595.6
In reply to
7595.5
The prints from the B9creator are UV set resin. Did a direct investment and burn from the 3d prints. I Burn to 850 degrees for a clean burnout. Good to cast after that.
https://www.b9c.com
Hope that helps
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
hep
7 Sep 2015 (7 of 9)
7595.7
In reply to
7595.6
Thanks - i see. i have done similar with wax, but that melt at low temperatures (bigger parts though). But of cause the resin should burn as well.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Metin Seven (SEVENSHEAVEN)
7 Sep 2015 (8 of 9)
7595.8
Classy designs Alex. Did you use Flow for the rounded shapes?
http://metinseven.com — 3D modeling • design • images
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
AlexPolo
7 Sep 2015 (9 of 9)
7595.9
In reply to
7595.8
Yep flat shapes generated to flow over basic 3d forms - great work flow.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-4
5-9
