WebGL and require('gl-matrix');
Please excuse dumb question :-)
Is it possible to use glMatrix with new Moi scripts?
var glMatrix = require('gl-matrix');
var assert = require('assert');
https://github.com/toji/gl-matrix
http://glmatrix.net/
Brian
Then there is something called JSON...
7593.2 In reply to 7593.1
Yes, you can use this library.
I'm not sure, but it looks like it is just a math library for fast calculations, and doesn't use any WebGL functions.
You need to place all functions in the one file, and delete all require commands. I hope it will work fine.
7593.3 In reply to 7593.1
Hi Brian, yes like Max says if it's just a pure javascript library and does not actually require WebGL then you should be able to use it - but the browser that MoI's UI is based on does not support WebGL itself I don't think.
You also posted code like this:
This is not likely to work as-is because Javascript does not have a built in "require" function (which is like an #include), were those examples from using it within a Node.js environment probably? I think Node.js adds that function into its global script environment, it's not part of the stock default script environment at least I don't think so.
7593.4 In reply to 7593.3
Thank you Max and Michael.
So there is a possible source of some functions, to be converted to Moi compatible things.
