Curve got straightened out in front view
All  1  2-4
7590.2 In reply to 7590.1
Please post .3dm.
7590.3 In reply to 7590.1
Hi Shadowcaster, thanks I'm glad that you are liking MoI!
What you are showing there is a bug in the display engine - your actual curve is fine it's just not being displayed properly when it goes straight like that.
It's unfortunately a somewhat difficult bug to fix without causing some general performance degradation to all curve drawing if not done very carefully - that's why I have not attempted to fix it so far and actually may not attempt to fix it since it only happens in very particular circumstances (curve with minimal points and a particular "S" shape with same direction end tangents and curve midpoint right at midpoint between the line through the end points).
See here for some more description:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4101.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=7405.12
If it's getting in your way a lot you should be able to avoid it by using Edit > Add pt to insert a new point into the curve, you can do it with control points turned off to keep the same curve shape.
7590.4 In reply to 7590.3
Thanks for the answer.
Show messages: All  1  2-4
