reverse spline direction?
7584.1
I'm not sure this is the reason I kepp getting problems with flow but is there a way to reverse the spline direction?
I'm trying to model a conveyor with a u shape for the single elements.
So I have the single elements arrayed along a straight line (the length of the curved conveyor shape).
now I select all the elements, click flow, click on the straight line, click on the round conveyor shape and now the u shape is turned upside down...
the segment of the elements that should be facing outside are facing the inner side of the conveyor... How can I adjust that? It worked fine that way for 2 conveyor shapes, the 3rd one suddenly makes problems.
I tried mirroring the splines of the conveyor or the line along the array but that doesn't do the job.
now I'll just try the array mirrored - but is there an easier way to refine direction for the splines if this happens?
What you see is what you believe - so don't. (from an Amiga500 demo)
7584.2 In reply to 7584.1
Hi macray - for reversing directions that's controlled by the location where you click on both curves. Click near the end of the base curve that you want to use as the start, and then click near which endpoint of the target curve you want to use as the start on that one.
But I'm not entirely sure if reversing directions is actually your problem - if you have 2 curves that are bending around in 3D space and not on a common plane then there can be banking involved when things flow along the bent curve. The best way to control that is to make the 2 curves be in one plane, there is not any way right now to explicitly control the rotation around the target curve unless the 2 curves are coplanar.
If none of this describes your issue it would help a lot if you could post the 3DM model file with your objects you are trying to flow in it. It's difficult to figure out what you are running into just from a description alone.
7584.3 In reply to 7584.2
okay.. when trying different points on the target spline there was no effect, but with a different point on the starting shape the desired effect was achieved an the flow works as intended.
head >> wall
thanks for the help!
7584.4 In reply to 7584.3
No problem macray - yes the specific location you click on both the base and target curves are significant. Try to click towards one end of each of them, on the sides that you want to use as the starting side for each of them.
If you click somewhere in the middle of the base curve that won't be good because the end closest to where you click is used as the start and if you click in the middle it won't be controlled very well.
