MoI or Rhino to start
 1-16  17-23
7575.17
Thanks all.
It's really clear to me the difference among polygonal and solid modeling in the theory, but never worked on solid modeling sw.
Understood probably the best choice is to have both, need to further evaluate if MoI good as is for modelling is really what we need.
Message 7575.18 deleted 15 Feb 2016 by DAVIDE445
7575.19
Returning to this topic, we will order tomorrow our first 3d scanner (DAVID SLS3), we received just Saturday our first 3d printer (a new FDM advanced model not yet on the market).
We want start using both together, understood is not immediate but possible using some external programs to import the scan point cloud into MOI, wanted to know how adapt is MOI to model following the resulting mesh as guide.
7575.20 In reply to 7575.19
Growshapes.com states output as obj, stl, or ply, and a hefty price.
What will the file sizes be?
Brian
7575.21 In reply to 7575.19
Hi davide,
MoI is not very good at this type of task - it has not been designed to do reverse engineering of mesh data into NURBS solids, that really requires a special dedicated toolset that is pretty different from the toolset used for regular CAD modeling.
You can use MoI for doing 3D printing, but the way you use it is by drawing your object from scratch and then exporting your model to STL format, not by trying to convert scanned data.
There are various specialized programs that are designed to work with point cloud data, you might check out Geomagic , or also look at some of the reverse engineering plugins that run inside of Rhino: http://wiki.mcneel.com/rhino/reverseengineering
But MoI itself is not focused on that type of process.
7575.22 In reply to 7575.21
Thanks Michael.
Using MOI3D to draw the solid using the imported mesh (generated from the point cloud) just as a guide make sense?
I'm trying to find a smooth way to approach the problem, since all the other packages I was researching such as Rhino, Geomagic Wrap/Design X or SpaceClaim appear to be a steep start for beginners.
7575.23 In reply to 7575.22
Hi David,
It's theoetically possible for some cases but there are many situations where it's not very feasible like with areas that the mesh has branching areas.
Reverse engineering just tends to be an overall a complex area which MoI is not specifically equipped or designed to work with.
Show messages:  1-16  17-23
