Flarum - Open-source forum engine
All  1-3  4-9
And what about actual datas of this site ?
Does it possible to implement them in the new forum?
7573.5 In reply to 7573.3
Hi Marco that's great, I didn't notice that at first glance. This might be worth checking out in more detail once it has hit a stabilized milestone.
7573.6 In reply to 7573.3
Hi Marco,
> the side-pane is implemented already. By moving the mouse to the left side of the
> screen/browser window the discussion-list pane will slide out, but this can be pinned
> either via the icon or via config. As it is basically a slide-out menu, it will play rather well
> with most responsive UX approaches.
It's kind of set up a little weird though - the reason why I didn't notice it at first was that it does not seem to appear on the initial forum main page, it seems to only be an option once you have started to read a message... ?
How do you get the side pane to show up right from the start like when going directly to http://discuss.flarum.org/ ?
Still it's very promising that it at least has it - a persistent topics list is almost always missing from forums.
7573.7 In reply to 7573.4
The content of this forum is stored in a MySQL database that runs on the webserver.
It's possible but I'd probably have to write some custom code to move the data over to a new forum. So moving messages might involve quite a bit of work.
7573.8
Michael,
There's no "attachements" yet in Flarum but it's coming in the new versions
We need to keep an eye on this as it seems very promising :)
www.kuto.ch / 3D Designer & Photographer
7573.9 In reply to 7573.8
Hi Samuel, yes it's looking good, definitely the most promising one that I've seen around.
It seems to be based off of the organization style that I like which is a continuous stream of new messages with "tags" as a way to group them into categories.
The default look and feel is very nice.
I'd definitely agree that it would be good to keep an eye on it.
But it's likely that any switch over would involve a fairly substantial amount of work from me though.
One thing I don't like about it is that it doesn't seem to support Windows Server right now, so I'd have to set up a new server environment for it to run. This can be quite an undertaking to learn about setting things up so as not to run into security problems.
Show messages: All  1-3  4-9
