can't seem to get the update to work??
All  1  2-10
757.2 In reply to 757.1
Hi Matt, can you please check to see if your system date is correct?
The current beta is set to expire on September 15th, do you possibly have your system date set to September instead of July?
757.3 In reply to 757.2
Hi! Congratulations for the program. I have the same problem. Just now my beta version has expired.
757.4 In reply to 757.3
Hi Marauder, can you please check your system date (double-click on the clock in the system tray) and make sure it is correct, especially the month?
757.5 In reply to 757.4
My date is July, Monday 16, 2007
757.6 In reply to 757.5
Hi Marauder - and are you running the most recent version? The second-to-last released beta, version Apr-26-2007 was set to expire on July 11. So if you're running that one it is normal that it is expired.
But if you have installed the latest Jun-12-2007 version, that one is not set to expire until Sept 15th, so you should be ok if you download that one.
I'm almost ready to release another new beta though, probably tomorrow.
757.7 In reply to 757.6
Thank you.
757.8
hi guys..Yes, my system date is correct and the version I have installed is Beta June 12, 2007 still doesn't seem to work
757.9 In reply to 757.8
Hi Matt, please send me an e-mail to moi@moi3d.com and I'll send you back something that should get you running again.
If you ran even once with an incorrect date, it will remain expired even if you fix the system date after that.
757.10
ok, email sent!
Matt
Show messages: All  1  2-10
