PDF export always portrait format?
7569.1
is there a way to configure the PDF export to something else than portrait mode? usually MoI is displayed in landsacpe mode so I find the export a bit strange. there is always so much free space above and below...
it might be fine to just take the viewport aspect ratio for the pdf aspect ratio.
Otherwise it work really fine for me.
thanks for that functionality!
What you see is what you believe - so don't. (from an Amiga500 demo)
7569.2 In reply to 7569.1
Hi macray - sorry no there is currently not any way to change the PDF export page configuration. It's just fixed at a 8.5 x 11 portrait sheet. Since it was a new feature kind of late in the v3 timeframe the focus for it was just on the content generation and not on other less critical details like the page configuration. I considered that to be a lower priority than the actual content since you can import the PDF file into a 2D vector drawing app like Adobe Illustrator, etc... to put it on whatever kind of page you need.
I do expect to add some control for it at some point here though.
