MoI v4 beta?
 1-13  14-33  34-53  54-68
7568.34 In reply to 7568.33
Hi Marc, sorry just more of the same - getting close... I should be able to knock another thing off the list tonight and it's getting really short.
Message 7568.35 deleted 10 Mar 2017 by FRACTIONALIST
7568.36 In reply to 7568.35
Hi Ced,
> Is there a way you can design v4 one of perhaps 2 different ways? E.g. Have a customized
> INSTALL option where you could pick and choose what installs over the current v3 installation,
> or have an ADD-ON zip that would install a selection of options = such as 'lighting - objects
> - icons - interface skins - points - etc?
It would take a lot of time and effort for me to do that, so unfortunately the answer is no that will not happen for v4.
In the future I do want to do some work in this area though to make it easier to do customizations and to make them stored external to MoI like in your user data folder so they can persist between installs but there is a tricky problem around this area which is to merge together changes in the default UI with your own changes in an automated way.
For now when you customize MoI you should keep a record of what you do so you can repeat it with new releases.
If you don't want to do that then either don't customize it or wait until the final v4 release before using v4 so you will only need to do it one time.
When you apply all these customizations like you've been so fond of, you should understand that you are outside of the standard supported target of Moi and you are taking responsibility for doing your own work on it.
7568.37
Hmmmm - perhaps expand the controls on the 'what-ever-its-called' GUI Interface customizer so that you can make MORE changes, it already has a lot of great options.
If I add NOTES to the HTM - and send you that HTM code with the notes within it - would that help you? Then anyone could scroll down the code and know what does what and how to change it?
If I'm just one voice in the wilderness - nevermind - however - it doesn't seem that difficult to add notes to the code.
My biggest problem was FINDING what I was looking for! Once somebody pointed me at the appropriate htm page - and the title of the object - it was easy!
I'd be willing to help beautify the hml code with notes - and add a zip with png files - etc., if that would be something you would like to offer to the inmates of this lunatic asylum.
Cheers,
Ced
7568.38 In reply to 7568.37
Hi Ced, if you want to help others with your notes just post them here on the forum, it's not necessary to send them to me.
7568.39
Hmmm... wonder how different the folder placement & sidePane.html will be in v4... as well as the png which were altered for the interface.
Looks like I'll need to wait and see, then compare old & new, and at that point write a side-by-side instruction manual on how to customize Moi3d v4.
I'll be hard pressed (again) to glean the latest & greatest scripts, shortcuts, nodes, appended command customizations, lighting effects, object window controls, folder layouts, new font styles, icons & window view spacer color changes & window title header size & placements.
If nothing else I'll add NOTES in the HTML with a zip containing the grab bag of png's.
If you feel caffeinated - HTML notes WHERE those rid bits populate your code within the pages would be useful in that you wouldn't become exasperated being peppered with 'where is..." 24/7.
You can bet the forum will overflow with chatter upon release of v4.
Ha-ha! The horror!
Ced
7568.40 In reply to 7568.39
Hi Ced, the v4 SidePane.htm is about 95% the same as v3, there are some tweaks to CSS values and a couple of small structural changes like a an additional <div> wrapper around palette content, to adapt to changes in the HTML rendering engine. It's now using a newer version of WebKit and there a few differences in behavior from the old one to have better HTML standards compliance. Also MoI v3 was using an early version of flexbox containers that is now deprecated in WebKit, I've switched over to using the standard flexbox now so there are a few changes to CSS property names and container structures because of that.
Overall the changes are small tweaks though, nothing major. However, it won't work to just copy the entire v3 UI completely over, you'll have to reapply your changes within the new UI.
7568.41
Michael,
"For beta or worse?"
Perhaps 'beautify' the sidePane.htm code & add descriptive notes?
Then have a download area for ADD-ONS - it would be easy to customize so much - and facilitate adding the Lighting Options, Objects, Shortcuts & Scripts with an INSTALL checkbox where one could choose an EXPRESS INSTALL or CUSTOM INSTALL!
See below:
7568.42 In reply to 7568.41
Hi Ced,
It's already as beautified as it needs to be and there are already comments in there about the different sections like the title bar, filename and context area. So no I don't expect to put any more in there currently.
> Then have a download area for ADD-ONS - <....>
I've already given you the answer on this about 10 times already.
Message 7568.43 deleted 10 Mar 2017 by FRACTIONALIST
7568.44 In reply to 7568.43
Hi Ced, I didn't design the color scheme myself, it was done by a professional designer. I've received positive comments specifically about that so I know that a lot of people do not agree with your assessment.
It's not likely to change soon so I'd appreciate it if you would quit with the snarky comments over and over and over again. If you don't like it then you are free to change it, which I thought you'd done so I don't really understand your continuing complaints about it.
As I've mentioned about another 10 times again, in the future I do want to ship MoI with a couple of different themes that you could more easily choose between. It will take some infrastructure work to do that, and I consider the color scheme to be mostly a cosmetic detail of minimal importance compared to stuff like workflow and reliability so it isn't a priority as of yet.
7568.45
Hello,
Ced, your customized interface is about a hundred steps backward in usability and clarity, you've managed to clearly demonstrate what not to do when it comes to UX design. I'd suggest educating yourself on what constitutes good UX before knocking someones work.
7568.46 In reply to 7568.45
I didn't know it was called UX design, but a google search of "good ux design" brings up lots of information,
including different kinds of color blindness recommendations. I still have to read and study more.
MoI's UX is already superb, in my opinion, but maybe nodeeditor could use some alternative, lighter themes?
I'd kind of like to combine the Construct and Transform menus, if it would fit. I think someone already did so.
7568.47 In reply to 7568.45
I don't think he understands that things like the GUI Builder were made by "Chipp"!!! Along with 100's of the other things he's "managed to find"....(made by others in the forum. Not Michael)
I spent 9 or 10 years collecting all those, that he loaded, here by following the forum, and collecting them........
7568.48
Hello,
UX and UI are different disciplines, UX generally deals with how usable a product is, UI is how it looks. UX and UI do not have to go hand in hand, you can have a highly usable product that is horrible looking (good UX, bad UI), and a product that is a bear to use that looks great (bad UX, good UI).
Personally I'd rather have a product exhibit great UX and be less worried about UI, I can live with things not being pixel perfect if I can move around the interface without struggling. MoI does a great job in most areas when it comes to UX, some industry leading in my opinion. I'd prefer if MoI simply made minor refinements over time to it's UX without sweating over the UI, why fix if it isn't broken?
7568.49 In reply to 7568.48
Dear All,
I use MoI extensively with my work at least 5 hours a day, I find it a joy to use. It is very obviously that Michael has a considerable amount of passion that he has injected and continues to do so, which I know most here in this Forum greatly appreciate.
With reference to the ui, I find it refreshing simple and uncomplicated, unlike most other 3d packages that I have used and use. With such a fantastic UI it means that I can concentrate on creative design without getting bogged down with a clunky user interface, most of which I would rarely use!
Thank you Michael
James Elliott
www.jameselliott.co.uk
7568.50
An idea could be to split the forum in two sections
Main:where people can land for the first time and find modeling tips,workflows,questions about (what MOI is,what people need from Moi,after all... ;) )
Secondary:where people can find extra-stuff like math formulas,codes,nodes,java...HTML...CSS...???and maybe decide to leave modeling and become programmers :)
M
7568.51
Yeah. Adding all the cool stuff is a nightmare. It's confusing finding the scripts, nodes, hotkeys, lighting options, objects, GUI customizations and worst is the paltry notes in the sidePane HTML code so you need to read the whole forum to figure out how to make Moi3d a full metal jacket!
Apparently my beef isn't popular.
Doubt I'll upgrade if I have to go through the whole process once more, may as well stay with Rhino, 3dCoat & KeyShot, at least it has the easy-on-the-eyes interface, and no need to find the needles in the haystack.
Cheers,
Ced
7568.52 In reply to 7568.50
Hi Mauro,
Few days ago I found a good forum engine: https://discuss.flarum.org/
In my opinion it could be a best engine for a next generation MoI community forum.
If Michael will implement a tag system to this forum, it will be great.
7568.53 In reply to 7568.52
Privet Max,
lately i found the forum filled by extra-stuff,as i wrote above
that stuff is useful but also in contradiction with Moi's Zen philosophy (be simple,be clear )
A user that jump into the forum for the first time and watch snippets of html code or some nodes can be scared ! :)
So,moving that advanced stuff into a secondary page could be coherent with Moi's Zen philosophy
All depends by Michael...being a one-man-band could have no time for these things
If he'll decide to leave the forum as is,it's ok for me!
There are ten years that i use Moi successfully,using same clear,simple...outdated :) but at the same time like a "fresh-breath" UI
Every time it was and it is a real pleasure!
Once again:thank you so much for all tools you shared with us Max !
M
Show messages:  1-13  14-33  34-53  54-68
