.obj object offset
All  1-2  3-6
7564.3 In reply to 7564.2
Hi Andrei, I've never heard of a problem like that before. Is it possible that in Moi you've set a custom cplane and it's the cplane location that you're viewing there?
If not then please post the 3DM model file with that object in it and the .obj file that you generated from it and I'll examine them and see what I can find.
7564.4 In reply to 7564.3
Michael Gibson,
Many thanks about idea with CPLane! I just examine my projects, the thing was that I have set Template file with shifted CPlane... It drived me crazy to uderstand what is wrong, becouse I reset all settings and reinstal MoI but problem was still here, many thanks again it was Template File... :)
7564.5 In reply to 7564.4
No problem Andrei - yes if you have a custom cplane set (which if it's in the startup template file means you will get it in your default opening setup), that will control the visual placement of the grid in MoI but not have any effect on .obj export.
Sounds like you are all set up now.
7564.6 In reply to 7564.5
Yes, thanks!
www.samardac.com
Show messages: All  1-2  3-6
