Is there a Rebuild-Smooth-Script for corner-points in Moi3d?
7558.1
Hello dear ;)
Is there a Rebuild-Smooth-Script for corner-points in Moi3d? Is there a Rebuild-Smooth-Script in Moi3d? Similar to the Rebuild Script, this script should first locate all corner points and replace with 1 or 2 non-Corner-Points very close (but not too close) by the corner point, this would be a nice script? I did clean nearly all corner ponits by hand, because it looks often better if e.g. blended surfaces don't have corner point between the edges (curves).
7558.2 In reply to 7558.1
Hi Lordfox, sorry I don't know of any script exactly like that right now. It's a bit difficult for scripts to deal with control points currently, there is not a lot of stuff set up for scripts to access control point in particular.
It is possible to round off sharp corners in a curve using Construct > Fillet though.
7558.3
Hey, thanks, my english is not the best - but today I found a script, that is useful - but not at all, because it changes the curve in e very heavy way ... I mean the DELCORNERS script, I found it here
http://moi3d.com/forum/index.php?webtag=MOI&msg=6058.43
But my solution is - Rebuild the curve with more points and after that - DELCORNERS Script :) ... but maybe - its my suggestion - this script should delete the corner and set two or one smooth corners in close to the corner :)
7558.4 In reply to 7558.3
yes, but sorry in French ! ;)
