Remove bevel from model
All  1-5  6
7554.6 In reply to 7554.5
Hi Randy,
> Am I on the right track for removing the fillet from the notch in the surfaces or
> is there an easier way to do it?
You were on the right track and doing the right things - it's just that Trim was being finicky about these particular curves.
It's possible in this particular case that not scaling up initially after import might help... The thing that's a bit tricky about scaling is the gaps between things also scale up as well.
Over time I've moved more of MoI to work better on different sized objects, so it's possible that the past advice may not apply in all cases anymore... But it kind of depends on the particular situation.
Show messages: All  1-5  6
