Hi All,
I'm happy with MoI not being parametric, but...
I've been playing with OpenSCAD for the last few months as part of hacking the Mendel90 open source printer project. For someone more used to modelling interactively, (using MoI, OnShape, etc) it can require a frustratingly complex number of boolean commands to achieve something that in MoI would be straightforward.
Now that I appreciate the elegance of it's parametric abilities - and accept inherit limitations, I began to wonder if a similar, identical or extended version of the openSCAD language, (with interpreter to MoI script) might be a good basis on which to make MoI parametric, without bloating MoI itself into something it was never intended to be. David Morrill and possibly others, made some headway on this kind of scripting interface a few years ago; unfortunately these projects seemed to have evaporated. Does anyone know anything different?
From the 'about' page, this is how Open S CAD is described:
"OpenSCAD is not an interactive modeller. Instead it is something like a 3D-compiler that reads in a script file that describes the object and renders the 3D model from this script file. This gives you (the designer) full control over the modelling process and enables you to easily change any step in the modelling process or make designs that are defined by configurable parameters."
Cheers,
Hamish
